Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem Posílání dat po sériové lince
Mám takový program který uloží data do bufferu a já potřebuji ty data pěkně po sobě posílat na sériový monitor
#include "esp_camera.h"
// Pin definition for CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
camera_config_t config;
void setup() {
  Serial.begin(115200);
  initCamera();
void loop() {
  takePhoto();
  delay(10000);
void initCamera() {
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if(psramFound()){
    config.frame_size = FRAMESIZE_XGA;//FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
    config.jpeg_quality = 10;
    config.fb_count = 2;
  } else {
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Init Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
void takePhoto() {
  camera_fb_t * fb = NULL;
  // Take Picture with Camera
  fb = esp_camera_fb_get();
  Serial.print("Velikost obrazu: ");
  Serial.print(fb->len);
  Serial.print(" B,");
  Serial.print((fb->len)/1024);
  Serial.println(" KB");
  if(!fb) {
    Serial.println("Camera capture failed");
    return;
   * Free buffer cam
  esp_camera_fb_return(fb);
velikost dovedu zjistit a vypsat na sériovém monitoru díky
A otázka je aká? Posielať data na seriový port? Máš buffer - pošli ho... Serial.write(buff, sizeo…
pme 17.07.2021 18:26
pme
fb = esp_camera_fb_get(); fb to je ten buffer díky
Víťa 17.07.2021 19:21
Víťa
Mám pocit, že snažíš o niečo takéto: https://forum.arduino.cc/t/transfer-pictures-from-esp32-cam-to…
pme 17.07.2021 19:57
pme
Tak to dobře Serial.write(fb->buf,fb->len); ale jak to převést do hex formátu? a popřípadě do zapsat… poslední
Víťa 18.07.2021 19:16
Víťa
A otázka je aká?
Serial.write(buff, sizeof(buff));
