Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem Stary nebo inovovany virus?
Tak bratr dostal na seznam email tohoto zneni ( vazne jsem se pri cteni bavil ):
Dear Microsoft Customer,
Please notice that Microsoft company has recently issued a Security Update for OS Microsoft Windows. The update applies to the following OS versions: Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows Millenium, Microsoft Windows XP, Microsoft Windows Vista.
Please notice, that present update applies to high-priority updates category. In order to help protect your computer against security threats and performance problems, we strongly recommend you to install this update.
Since public distribution of this Update through the official website www.microsoft.com would have result in efficient creation of a malicious software, we made a decision to issue an experimental private version of an update for all Microsoft Windows OS users.
As your computer is set to receive notifications when new updates are available, you have received this notice.
In order to start the update, please follow the step-by-step instruction:
1. Run the file, that you have received along with this message.
2. Carefully follow all the instructions you see on the screen.
If nothing changes after you have run the file, probably in the settings of your OS you have an indication to run all the updates at a background routine. In that case, at this point the upgrade of your OS will be finished.
We apologize for any inconvenience this back order may be causing you.
Thank you,
Steve Lipner
Director of Security Assurance
Microsoft Corp.
a v priloze KB593900.exe
No to zas bude dotazu na odstraneni viru a likvidaci pc.
Ach bože... Třeba budou lidi opatrní: search
L-Core 14.10.2008 16:20
L-Core
Koukal jsem, ze ten nazev souboru je email co email jiny ( dve antispam/antivirus brany co mam pod s…
JR_Ewing 14.10.2008 17:05
JR_Ewing
Na váš předmět vyhledávání - KB593900.exe - nebyl nalezen žádný odkaz. stejný výsledek i s pouhým K… poslední
mia 14.10.2008 19:52
mia
Thank you, Steve Lipner Director of Security Assurance Microsoft Corp Lipnera muší klepnout pepka.…
kmochna 14.10.2008 16:43
kmochna
Koukal jsem, ze ten nazev souboru je email co email jiny ( dve antispam/antivirus brany co mam pod spravou ). Ale virus je stejny, je to nejaky Infostealer. Za poslednich 25 hodin neco pres 700 vyskytu.
stejný výsledek i s pouhým KB593900, i na englickým gúglu :-(
