Nechce sa mi hladat info tak len spekulujem: je to boot particia (active) takze predpokladam ze tam…
MM.. 22.01.2009 16:49
Vista to stejné nemá. vzhledem k velikosti to bude asi sloužit k tomu co popisuje MM
tank 22.01.2009 17:10
tank
No, ja spis ze zvedavosti, az se neco potento, abych vedel co vlastne delam. Jinak jsem se do ni sam…
jirka44 22.01.2009 17:28
jirka44
Unknowingly to many Windows 7 users, a hidden primary system partition which is active will be autom…
mkmt 22.01.2009 17:32
mkmt
Veledekuji, tak tohle jsem nenasel....
jirka44 22.01.2009 17:44
jirka44
V tom pripade by to ale mali robit vsetky verzie, nielen 64bit.
MM.. 22.01.2009 17:47
No, uz chapu, musis si precist cely odkaz, je to tam hezky vysvetlene. Ja jsem instaloval 32 na driv… poslední
jirka44 22.01.2009 17:50
jirka44
Nechce sa mi hladat info tak len spekulujem: je to boot particia (active) takze predpokladam ze tam je nejaky bootloader ktory nieco simuluje alebo prepne CPU na 64bit mod apod. Mozno na nejakych doskach v buducnosti na ktorych bude BIOS splnat nejake novsie veci (ze by UEFI?) bude vediet priamo bootovat tu systemovu a nebude to vytvarat tu specialnu, netusim.
Inac teoreticky malo by sa dat priradit jej pismeno a pozriet sa ze co tam na nej je. Ale nepozastavoval by som sa nad tym pokial ten Win funguje.
Unknowingly to many Windows 7 users, a hidden primary system partition which is active will be automatically and forcefully created by setup during installation of Windows 7. The additional separate standalone NTFS partition, which is not labeled with any drive letter or path, has the size of 200 MB, but only occupy 32 MB of it with 168 MB remains free.
The small 200MB partition actually holds Windows Recovery Environment (WinRE), which only available from DVD installation disc in previous operating system such as Windows Vista (see how to launch WinRE on DVD). The partition holds system files and bootable files that are essential to boot the Windows 7 properly in the event of the need to recover the OS in the event of corruption. The 200MB partition is pretty much similar to many recovery partition that been made on factory installation by most OEMs on the computer they sold.
http://www.mydigitallife.info/2009/01/09/how-to-av oid-200mb-hidden-system-partition-from-been-create d-during-windows-7-installation/
