 Phpmyadmin
				Phpmyadmin
					Mám problém s nastavení phpmyadmin aby při spuštění to po mě chtělo jméno a heslo. Když nastavím $cfg['Servers'][$i]['auth_type'] = 'http'; tak by to po mě mělo vždy žádat jméno a heslo. Ano to žádá ale, když ho tam napíšu úplně dobře tak to po mě chce znova a prostě nedostanu se tam. Nevíte, co dělám špatně?? Posilám zdroj jak to mám nastavené.
<?php
/* $Id: config.default.php,v 2.20.2.1 2005/11/23 10:34:32 nijel Exp $ */
// vim: expandtab sw=4 ts=4 sts=4:/**
* phpMyAdmin Configuration File
* All directives are explained in Documentation.html
* Your phpMyAdmin URL.
* Complete the variable below with the full url ie
* http://www.your_web.net/path_to_your_phpMyAdmin_di rectory/
* It must contain characters that are valid for a URL, and the path is
* case sensitive on some Web servers, for example Unix-based servers.
* In most cases you can leave this variable empty, as the correct value
* will be detected automatically. However, we recommend that you do
* test to see that the auto-detection code works in your system. A good
* test is to browse a table, then edit a row and save it. There will be
* an error message if phpMyAdmin cannot auto-detect the correct value.
$cfg['PmaAbsoluteUri'] = '';/**
* Disable the default warning that is displayed on the DB Details Structure page if
* any of the required Tables for the relationfeatures could not be found
$cfg['PmaNoRelation_DisableWarning'] = FALSE;/**
* The 'cookie' auth_type uses blowfish algorithm to encrypt the password. If
* at least one server configuration uses 'cookie' auth_type, enter here a
* passphrase that will be used by blowfish. The maximum length seems to be 46
* characters.
$cfg['blowfish_secret'] = 'xampp';/**
* Server(s) configuration
$i = 0;
// The $cfg['Servers'] array starts with $cfg['Servers'][1]. Do not use
// $cfg['Servers'][0]. You can disable a server config entry by setting host
// to ''. If you want more than one server, just copy following section
// (including $i incrementation) serveral times. There is no need to define
// full server array, just define values you need to change.
$i++;
$cfg['Servers'][$i]['host'] = 'localhost'; // MySQL hostname or IP address
$cfg['Servers'][$i]['port'] = '3306'; // MySQL port - leave blank for default port
$cfg['Servers'][$i]['socket'] = ''; // Path to the socket - leave blank for default socket
$cfg['Servers'][$i]['connect_type'] = 'tcp'; // How to connect to MySQL server ('tcp' or 'socket')
$cfg['Servers'][$i]['extension'] = 'mysql'; // The php MySQL extension to use ('mysql' or 'mysqli')
$cfg['Servers'][$i]['compress'] = FALSE; // Use compressed protocol for the MySQL connection
// (requires PHP >= 4.3.0)
$cfg['Servers'][$i]['controluser'] = ''; // MySQL control user settings
// (this user must have read-only
$cfg['Servers'][$i]['controlpass'] = ''; // access to the "mysql/user"
// and "mysql/db" tables).
// The controluser is also
// used for all relational
// features (pmadb)
$cfg['Servers'][$i]['auth_type'] = 'config'; // Authentication method (config, http or cookie based)?
$cfg['Servers'][$i]['user'] = 'root'; // MySQL user
$cfg['Servers'][$i]['password'] = 'ferko001'; // MySQL password (only needed
// with 'config' auth_type)
$cfg['Servers'][$i]['only_db'] = ''; // If set to a db-name, only
// this db is displayed in left frame
// It may also be an array of db-names, where sorting order is relevant.
$cfg['Servers'][$i]['verbose'] = ''; // Verbose name for this host - leave blank to show the hostname$cfg['Servers'][$i]['pmadb'] = 'phpmyadmin'; // Database used for Relation, Bookmark and PDF Features
// (see scripts/create_tables.sql)
// - leave blank for no support
// DEFAULT: 'phpmyadmin'
$cfg['Servers'][$i]['bookmarktable'] = 'pma_bookmark'; // Bookmark table
// - leave blank for no bookmark support
// DEFAULT: 'pma_bookmark'
$cfg['Servers'][$i]['relation'] = 'pma_relation'; // table to describe the relation between links (see doc)
// - leave blank for no relation-links support
// DEFAULT: 'pma_relation'
$cfg['Servers'][$i]['table_info'] = 'pma_table_info'; // table to describe the display fields
// - leave blank for no display fields support
// DEFAULT: 'pma_table_info'
$cfg['Servers'][$i]['table_coords'] = 'pma_table_coords'; // table to describe the tables position for the PDF schema
// - leave blank for no PDF schema support
// DEFAULT: 'pma_table_coords'
$cfg['Servers'][$i]['pdf_pages'] = 'pma_pdf_pages'; // table to describe pages of relationpdf
// - leave blank if you don't want to use this
// DEFAULT: 'pma_pdf_pages'
$cfg['Servers'][$i]['column_info'] = 'pma_column_info'; // table to store column information
// - leave blank for no column comments/mime types
// DEFAULT: 'pma_column_info'
$cfg['Servers'][$i]['history'] = 'pma_history'; // table to store SQL history
// - leave blank for no SQL query history
// DEFAULT: 'pma_history'
$cfg['Servers'][$i]['verbose_check'] = TRUE; // set to FALSE if you know that your pma_* tables
// are up to date. This prevents compatibility
// checks and thereby increases performance.
$cfg['Servers'][$i]['AllowRoot'] = TRUE; // whether to allow root login
$cfg['Servers'][$i]['AllowDeny']['order'] // Host authentication order, leave blank to not use
$cfg['Servers'][$i]['AllowDeny']['rules'] // Host authentication rules, leave blank for defaults
= array();?>
Autentifikaci máš nastavenou config, ne http.
Omlouvam se ja to spatne opsalmam to tak:
<?php
* characters.
$i = 0;
$i++;
// features (pmadb)
$cfg['Servers'][$i]['auth_type'] = 'http'; // Authentication method (config, http or cookie based)?
= array();
Problém by mohl být v tom, že nemáš nastavenou proměnnou $cfg['PmaAbsoluteUri'].
Ta by měla být detekována automaticky, ale možná to z nějakého důvodu v tvém případě nefunguje.
No prave ze jsem zkousel aji tohle to nastavit a taky nic. No na tom mi nesejde ze tam nemusim dat heslo a jmeno ale jak udelat at je to bezpecne?? At mohu pristupovat jen s danych adres ip??
Poslední dva řádky v tom konfiguračním souboru...
dekuji za radu. Vyreseno!
