pro evolution soccer 2009
jde hrát proti sobě na jednom pc,? popřípadně jak to nastavit? myslim na klávesnici a na joysticku rumble pad 2,,díky
Předmět | Autor | Datum |
5 sekund na google:
Yes you can, You just need to set you pad(device) as controller 2 in your setti… poslední Hoppus 10.02.2009 11:05 |
Hoppus |
5 sekund na google:
Yes you can, You just need to set you pad(device) as controller 2 in your settings.
That means:
Controller 1 = Keyboard
Controller 2 = Joypad
Hope it will help you
ust go to settings.exe and set your gamepad to Controller 2. It should work ingame - the keyboard will act as controller 1, even if you don't see it in the settings.
Osobne som to neskusal, takze neviem zarucit.
