Likely a software coding error. Many programs require a baseline Operating System version. However i…
host 19.02.2009 16:23
Podívej se na index.php, tam se řeší problémy Pinnaclu poslední
leo 19.02.2009 19:15
leo
Operating System version. However instead of equal to or greater
the program version check was probably incorrectly coded to just
check for SP2. You might have to check with Pinnacle for a patch.
