herni pc - doporučte konfiguraci
Ahoj, chtel bych si koupit novy pc, ale protoze se v tom vubec neorientuji obracim se na vas...
pc by mel byt hlavne na hrani (relativne narocnych her, Crysis, Mirror's Edge atp.), casto taky surfovani na netu a obcasne sledovani filmu, stat by mel neco kolem (pres) 10 000 kc (bez periferii, os a hdd), nemam zadne extremni naroky na hlucnost(resp. nehlucnost, staci kdyz nebude slyset pres hudbu)
pro priblizeni - vlastnim uz nasledujici stroj a chtel bych, aby to melo srovnatelny vykon (funguje tam plynule Crysis na stredni/vyssi detaily v 1280x1024):
SiSoftware Sandra
Processor
Model : Intel(R) Core(TM)2 Duo CPU E4500 @ 2.20GHz
Speed : 2.20GHz
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Dual-Core
Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
System
Mainboard : Intel Corporation DG33BU
Bus(es) : PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
System BIOS : Intel Corp. DPP3510J.86A.0305.2007.1112.1145
Total Memory : 1.98GB DIMM DDR2
Chipset
Model : Intel P35/G33/G31 Processor to I/O Controller
Front Side Bus Speed : 4x 200MHz (800MHz)
Total Memory : 2GB DIMM DDR2
Memory Bus Speed : 2x 333MHz (666MHz)
Video System
Adapter : ATI Radeon HD 3800 Series (512MB, PCIe 2.00 x16, PS3.0, VS3.0)
Graphics Processor
Adapter : ATI Radeon HD 38XX (RV670) (1.01, 512MB)
Storage Devices
ST3320620AS 320GB (SATA150, 3.5", NCQ, 16MB Cache) : 298GB (C:)
WDC WD1600JD-00GBB0 160GB (SATA150, 3.5", 7200rpm, 8MB Cache) : 149GB (D:)
Optiarc DVD RW AD-7170A (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
Hard Disk (C:) : 298GB (NTFS) @ ST3320620AS 320GB (SATA150, 3.5", NCQ, 16MB Cache)
Hard Disk (D:) : 149GB (NTFS) @ WDC WD1600JD-00GBB0 160GB (SATA150, 3.5", 7200rpm, 8MB Cache)
CD-ROM/DVD (E:) : N/A @ Optiarc DVD RW AD-7170A (ATA66, DVD+-RW, CD-RW, 2MB Cache)
3.5" 1.44MB (A:) : N/A
Network Services
Network Adapter : Intel(R) 82566DC-2 Gigabit Network Connection - Packet Scheduler Miniport (Ethernet, 100Mbps)
Změna předmětu, původně: herni pc (host)
pc na hranie s integr. grafikou? a este zo starej serie radeon 3800? si snad robis prdel...
daj tam intel dosku s minimalne P35 chipsetom, CPU E5200 a ked uz radeon, tak 4870, 512MB.
psal jsem, ze pc s uvedenymi parametry mam a chci si koupit nove, aspon se srovantelnym vykonem...
integrovana grafika tam byla (je i ted), krome ni je tam ta radeonka (neintegrovana)
Doplňující dotaz:
jedná se o upgrade staršího PC, tedy bez OS, HDD. Další komponenty ze starého (nebo jak to pochopit nejlépe) PC nepůjdou využít (skříň, mechanika atp.)? Která konkrétně je stávající grafika? ATI/AMD má na RV670 s 512 MB pamětí dvě grafiky, a to HD 3850 a HD 3870.
nejde o upgrade, ze stareho pc bude pouzity jeden hdd (na hry by mel stacit, ostatni data - filmy, hudba aj. - budou jinde), mechaniku nepotrebuju nejakou zbytecne drahou, nevyuzivam cd/dvd skoro vubec
stavajici grafika je HD3850
Tech deset litru ma byt za kompletni nove PC nebo za upg?
za nove (bez hdd, os a periferii - klavesnici si prozatim vezmu nejakou starou, mys mam jednu navic a monitor taky starsi, doufam ze v nejblizsi dobe koupim novy) , mozna se podari dat dohromady i neco pres tech 10
