Direct X
Mohl by mi někdo poradit s problémem s instalací direct X rozhraní?
Při instalaci vyskočí chyba a že je problém blíže popsaný v DXError.txt. Ten jsem našel a tady je jeho výpis...
Mohl by mi prosím někdo pomoct? Vůbec nevím co s tím a ten direct X bych docela potřeboval :)
[04/06/09 14:57:58] module: dxupdate(May 31 2007), file: dxupdate.cpp, line: 6613, function: CMDXInstall::Install
Failed API: InstallAssembly()
Error: (0x80131018)
Unable to install Microsoft.DirectX.Direct3DX.dll.
[04/06/09 14:57:58] module: dxupdate(May 31 2007), file: dxupdate.cpp, line: 2154, function: ExecuteCab
MDXInstall::Install() failed.
[04/06/09 14:57:58] module: dxupdate(May 31 2007), file: dxupdate.cpp, line: 5752, function: DirectXUpdateInstallPlugIn
ExecuteCab() failed.
[04/06/09 14:57:59] module: dxupdate(May 31 2007), file: dxupdate.cpp, line: 6613, function: CMDXInstall::Install
Error: (0x80131018)
Unable to install Microsoft.DirectX.dll.
[04/06/09 14:57:59] module: dxupdate(May 31 2007), file: dxupdate.cpp, line: 5772, function: DirectXUpdateInstallPlugIn
[04/06/09 14:57:59] module: dsetup32(May 31 2007), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
DirectXUpdateInstallPlugIn() failed.
[04/06/09 14:57:59] module: dsetup32(May 31 2007), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[04/06/09 19:16:54] module: dxupdate(May 31 2007), file: dxupdate.cpp, line: 6613, function: CMDXInstall::Install
Error: (0x80131018)
[04/06/09 19:16:54] module: dxupdate(May 31 2007), file: dxupdate.cpp, line: 2154, function: ExecuteCab
[04/06/09 19:16:54] module: dxupdate(May 31 2007), file: dxupdate.cpp, line: 5752, function: DirectXUpdateInstallPlugIn
Error: (0x80131018)
[04/06/09 19:16:54] module: dxupdate(May 31 2007), file: dxupdate.cpp, line: 5772, function: DirectXUpdateInstallPlugIn
[04/06/09 19:16:54] module: dsetup32(May 31 2007), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[04/06/09 19:16:54] module: dsetup32(May 31 2007), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
Jinak jedu na Vistě a grafika GF 9600GT
A tobě dodali Vistu bez DirectX? Nebo o co se vlastně snažíš?
napis sem presne ze co sa tam snazis instalovat a odkial si to stiahol a aku mas jazykovu verziu win.
pretoze dxupdate(May 31 2007) urcite v roku 2009 instalovat nechces. Stiahni si z microsoft.com najnovsi directx runtime, alebo neinstaluj nic.
