Problém s apachem
Mám problém,
nainstaloval jsem xampp 1.7.1 a nechodí mi tam apache. Musím dodat, že port 80 nemám obsazený.
Error log ve složce apache vypadá takto:
[Wed Jul 29 17:57:45 2009] [notice] Digest: generating secret for digest authentication ...
[Wed Jul 29 17:57:45 2009] [notice] Digest: done
[Wed Jul 29 17:57:48 2009] [notice] Apache/2.2.11 (Win32) DAV/2 mod_ssl/2.2.11 OpenSSL/0.9.8i PHP/5.2.9 configured -- resuming normal operations
[Wed Jul 29 17:57:48 2009] [notice] Server built: Dec 10 2008 00:10:06
[Wed Jul 29 17:57:48 2009] [notice] Parent: Created child process 2312
[Wed Jul 29 17:57:48 2009] [notice] Disabled use of AcceptEx() WinSock2 API
[Wed Jul 29 17:57:51 2009] [notice] Digest: generating secret for digest authentication ...
[Wed Jul 29 17:57:51 2009] [notice] Digest: done
[Wed Jul 29 17:57:53 2009] [notice] Child 2312: Child process is running
[Wed Jul 29 17:57:53 2009] [crit] (OS 10022)Byl zadán neplatný argument. : Parent: WSADuplicateSocket failed for socket 16251112. Check the FAQ.
[Wed Jul 29 17:57:53 2009] [crit] (OS 10022)Byl zadán neplatný argument. : master_main: create child process failed. Exiting.
[Wed Jul 29 17:57:53 2009] [notice] Parent: Forcing termination of child process 36
[Wed Jul 29 17:57:53 2009] [crit] (OS 109)Přesměrování bylo ukončeno. : setup_inherited_listeners: Unable to read socket data from parent
Nápověda na www.apache.net radí tohle:
Apache for Windows does not start. Error log contains this message: "[crit] (10045) The attempted operation is not supported for the type of object referenced: Parent: WSADuplicateSocket failed for socket ###". What does this mean?
We have seen this problem when Apache is run on systems along with Virtual Private Networking clients like Aventail Connect. Aventail Connect is a Layered Service Provider (LSP) that inserts itself, as a "shim," between the Winsock 2 API and Window's native Winsock 2 implementation. The Aventail Connect shim does not implement WSADuplicateSocket, which is the cause of the failure.
The shim is not unloaded when Aventail Connect is shut down. Once observed, the problem persists until the shim is either explicitly unloaded or the machine is rebooted. Another potential solution (not tested) is to add apache.exe to the Aventail "Connect Exclusion List".
Apache is affected in a similar way by any firewall program that isn't correctly configured. Assure you exclude your Apache server ports (usually port 80) from the list of ports to block. Refer to your firewall program's documentation for the how-to.
Takže, co mám udělat????
Díky, Karel
Opravdu smazat příspěvek?
Kluci od Apache píšou něco o tom, že máš v PC nainstalovanýho nějakýho VPN klienta, jest tak?
Co firewall, máme?
No jasně, mám online Armor...
