instalace pres cfg
tak prosim vas chci instalovat bmw road maps a mam tam dva cfg soubory. Na internetu psali že je mam otvorit v word padu a ono mi to vychrlilo normalni text. Pak psali že tam bude naky odkaz na instalaci toho programu. no proste tam psali toto
CFG files normally refer to configuration files for applications or your operating system. typically should not be opened manually, but is often saved in a text format that can be viewed in a text editor; can sometimes be moved or deleted to revert to a program's default settings.If you have Microsoft Office installed on a Windows machine, these may be referred to as "Microsoft Office Outlook Configuration Files", though other applications use configuration files with the .cfg file extension.
ale me to po otvoreni napsalo jen text a dal nic. Nevite jak takovy program nainstalovat?
Pokračujte zde: http://pc.poradna.net/q/view/449932-konfig-soubor- aplikace-m-office-outlok (host)
