Exchange 2010 - nelze přidat pravidlo pro transport
Pokaždé, když v Exchangi kliknu na New Transport Rule, tak se mi zobrazí tato chyba:
v System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
v System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
v System.Delegate.DynamicInvokeImpl(Object[] args)
v Microsoft.Exchange.Management.SystemManager.ExpressionCalculator.CalculateLambdaExpression(ColumnExpression expression, Type dataType, DataRow dataRow, DataRow inputRow)
v Microsoft.Exchange.Management.SystemManager.ExpressionCalculator.CalculateCore(DataRow dataRow, DataRow inputRow, IList`1 query)
v Microsoft.Exchange.Management.SystemManager.WinForms.AutomatedDataHandlerBase.FillColumnsBasedOnOnceLambdaExpression()
v Microsoft.Exchange.Management.SystemManager.WinForms.AutomatedDataHandlerBase.UpdateTable(DataRow row, String targetConfigObject, Boolean isOnReading)
v Microsoft.Exchange.Management.SystemManager.WinForms.AutomatedDataHandler.OnReadData(CommandInteractionHandler interactionHandler, String pageName)
v Microsoft.Exchange.Management.SystemManager.WinForms.DataHandler.Read(CommandInteractionHandler interactionHandler, String pageName)
v Microsoft.Exchange.Management.SystemManager.WinForms.DataContext.ReadData(CommandInteractionHandler interactionHandler, String pageName)
v Microsoft.Exchange.Management.SystemManager.WinForms.ExchangePage.<OnSetActive>b__0(Object sender, DoWorkEventArgs e)
v System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
Neočekávaná koncová značka Řádek 1, pozice 57
v System.Xml.XmlTextReaderImpl.Throw(Exception e)
v System.Xml.XmlTextReaderImpl.ParseDocumentContent()
v System.Xml.XmlLoader.ParsePartialContent(XmlNode parentNode, String innerxmltext, XmlNodeType nt)
v System.Xml.XmlLoader.LoadInnerXmlElement(XmlElement node, String innerxmltext)
v Microsoft.Exchange.Management.SystemManager.MarkupParser.set_Markup(String value)
v Microsoft.Exchange.Management.SnapIn.Esm.RuleEditor.RuleEditorCommon.GenerateExceptionsDescriptor(IList predicates, IList actions)
v lambda_method(ExecutionScope , String , String )
Čím by mohla být způsobena?
Vyřešeno reinstalací transport rule.
Nyní se objevuje chyba opět. Navíc jsem nainstaloval další server s Exchange 2010 a zprvu to fungovalo, nyní to také nejde. Pro Exchange jsem instaloval jen language pack a update rollup 1.
Chyba je v české lokalizaci Windows Server, stačí nastavit místní a jazykové nastavení na English, restartovat server a už to půjde. Doposud chybu Microsoft neodstranil, tzn. je nutné toto nastavení.
Frankus
take jsem to tak vyresil za pomoci Microsoftu, jen jsem zapomnel sem napsat reseni.
