Grafy v PHP a podpora na freewebhostingu
Neznáte nějaký freewebhosting s podporou JpGraph PHP knihoven ?
Ráz jsem testoval webzdarma a dopadlo to katastrofálně:
Ostatně můžete si to vyzkoušet sami:
<?php
include ("../jpgraph.php");
include ("../jpgraph_line.php");
$ydata = array(11,3,8,12,5,1,9,13,5,7);
// Create the graph. These two calls are always required
$graph = new Graph(350,250,"auto");
$graph->SetScale("textlin");
$graph->img->SetMargin(30,90,40,50);
$graph->xaxis->SetFont(FF_FONT1,FS_BOLD);
$graph->title->Set("Examples for graph");
// Create the linear plot
$lineplot=new LinePlot($ydata);
$lineplot->SetLegend("Test 1");
$lineplot->SetColor("blue");
// Add the plot to the graph
$graph->Add($lineplot);
// Display the graph
$graph->Stroke();
Vysledkem kodu bylo:
Warning: main(): open_basedir restriction in effect. File(/3w/wz.cz/m/jpgraph.php) is not within the allowed path. (from /3w/wz.cz/m/) in /3w/wz.cz/m//PHPfile.php on line 2
Warning: main(../jpgraph.php): failed to open stream: Operation not permitted in /3w/wz.cz/m//PHPfile.php on line 2
Warning: main(): Failed opening '../jpgraph.php' for inclusion (include_path='.:/usr/local/lib/php') in /3w/wz.cz/m//PHPfile.php on line 2
Warning: main(): open_basedir restriction in effect. File(/3w/wz.cz/m/jpgraph_line.php) is not within the allowed path. (from /3w/wz.cz/m/) in /3w/wz.cz/m/PHPfile.php on line 3
Warning: main(../jpgraph_line.php): failed to open stream: Operation not permitted in /3w/wz.cz/m//PHPfile.php on line 3
Warning: main(): Failed opening '../jpgraph_line.php' for inclusion (include_path='.:/usr/local/lib/php') in /3w/wz.cz/m//PHPfile.php on line 3
Fatal error: Cannot instantiate non-existent class: graph in /3w/wz.cz/m//PHPfile.php on line 8
Tak a teď raďte
sem se dival a ma to 2 verze, pro php5 a php4, mas spravnou ?
jo a jeste tam je nakej config, mas to dobre nastaveny ?
Tie súbory jpgraph.php a jpgraph_line.php máš kde umiestnené? O jeden adresár vyššie?
Už to začalo přeci jen trochu chodit.
Chtěl bych navrhnout mimo jiné webový editor grafu.,
Základem tohoto editoru je pochopitelně formát v jakém lze obrázek uložit.
Pokud formát není specifikován pomocí:
$graf->img->SetImgFormat("formát"); // je: jpeg, png, gif
Tak se automaticky vytvoří v gifu.
Jenže sranda je ta, že pokud zavolám tento řádek tak na mě JpGraph
Vyplivne tabulku že moje verze JpGraph nepodporuje daný formát. Ani gif dokonce.
Když jej vynechám tak proběhne vykreslení do GIFu OK.![]:(](https://static.poradna.net/images/smiley/evilworry.gif)
Nechápu.
Děkuji losovi. Nakonec se podařilo
rozjet všechny formáty.
Formát png a jpeg to bere. Formát gif to odmítá, ale lze jej vygenerovat tak, že není uveden.
Proč je tomu tak je pro mě jako programátora laika záhada
vsak co si neurobis napr. info.php:
a zistis, co vsetko php na tvojom free hostingu podporuje.
