blue screen
Dobry den,
chcel by som vas poprosit o pomoc kazde rano mi hadze blue screen aj 8 krat potom to prestane a pc ide dobre po zvysok dna na druhy den rano zase to iste.
vypis mnidump: c11e9d8686d5 ... a31db.html
Moj pc
Intel® Core™ i3 Processor 350M
ATI Mobility™ Radeon® HD 5145 1G DDR3 VRAM
Pamäť: 4096MB (2GB DDR3 1066MHz SDRAM) x 2
Pevný disk: 500GB(7200rpm) SATA
WIN 7 32 bit
Vopred dakujem za kazdu pomoc
tu je ten vypis takto
Dump File : 090110-21122-01.dmp
Crash Time : 1. 9. 2010 9:28:26
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : 0x00000014
Parameter 2 : 0x00000002
Parameter 3 : 0x00000000
Parameter 4 : 0x82a9d5f1
Caused By Driver : halmacpi.dll
Caused By Address : halmacpi.dll+5ba9
File Description : Hardware Abstraction Layer DLL
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7600.16385 (win7_rtm.090713-1255)
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\090110-21122-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7600
Dump File : 090110-18610-01.dmp
Crash Time : 1. 9. 2010 9:26:13
Parameter 4 : 0x82aa75f1
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\090110-18610-01.dmp
Major Version : 15
Dump File : 090110-19188-01.dmp
Crash Time : 1. 9. 2010 9:09:25
Parameter 1 : 0x00000028
Parameter 3 : 0x00000001
Parameter 4 : 0x82a4a0e9
Caused By Driver : ntkrnlpa.exe
Caused By Address : ntkrnlpa.exe+4682b
File Description : NT Kernel & System
File Version : 6.1.7600.16617 (win7_gdr.100618-1621)
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\090110-19188-01.dmp
Major Version : 15
to máš přenesený systém/disk z jiného pc, nebo korektně nainstalovaný z dvd?
ako preneseny nechapem? disk vsetko je v notebooku.
som to instaloval z DVD pekne, ted som nahodil aj linux a na linuxe to ide vse ok ale vo win stale kazde rano BS
http://pc.poradna.net/a/view/366229-ovladac-zaklad ni-desky
myslis ze je to chipsetom? ked istalujem co ma original DVD k notebook tak aj to tam je a aj to som nainstaloval a stale to robilo
ahoj taze chipsetom to ucite nie je, robi mi to stale som skusal ten z dvd, potom som zase reinstalol system a skusil som ten z ASUS support a stale kazde rano ked zapnem blue screen, pls pomoztee
Tak znova:
paměti jsi otestoval?
OS jsi instaloval jak?
Drivery k čipsetu jsi nainstaloval?
ano drivery naistaloval, os som instaloval kslasiak boot z DVD
a pameti otestovat jak?
memory diagnostic?
ano, to je pěkné, to se dá i čekat, ale to DVD je odkud? Standardní instalační DVD, nebo nějaká upravenina od výrobce?
ad paměť: memtest86
DVD normalne istalacne
lebo potom vlastne ten problem ustane, ked mi hazde BS tak dam pak F8 pri bude pusitm memory diagnos ono to urobi a uz nehadze BS, ale na druhy den rano zase to iste :(
to sis skládal sám, nebo je to reklamovatelné?
když tam strčíš na vyzkoušení jiný disk - můžeš na to nainstalovat jiný systém? (xp, linux)
ano linux tam ide dobre, no a som pustil memtest86 dojde to vzdy na 48% a pak s stale restartuje,
ne neskladal je to notebook mam ho 2 tyzdne
inac bol by si taky dobry a poslal mi icq alebo skype na moj mail pre rychlejsiu komunikaciu prosiim,
jokerstar@post.sk
no bolo to verziou memtes86 takze som to pustil bezi to 40 minut a pod ERROR mam cislo 731
takze co mam robit je pokazena RAM teda?
1,5 hodiny 2738 ERRORS, cize je pokazena RAM? mam ho dat teda reklamovat??
odpovie mi niekto???????
Ano.
