Error u RegTool2
Ahoj,
stáhl jsem si program RegTool2 (www.apptools.cz) a při instalaci mi to hází error viz. obrázek - http://img827.imageshack.us/img827/8707/errorprogr am.jpg - Zkoušel jsem nainstalovat Windows Installer z MS stránek, ale to mi vždy napíše: Aktualizace se Vašeho systému netýká.
Nevíte někdo moc prosím co s tím ?
Předem moc děkuji
Co je v tom logu?
The following properties have been set:
Property: [AdminUser] = true {boolean}
Property: [InstallMode] = HomeSite {string}
Property: [ProcessorArchitecture] = Intel {string}
Property: [VersionNT] = 6.0.0 {version}
Running checks for package 'Windows Installer 4.5', phase BuildList
Looking up path for special folder 'WindowsFolder'
Running check with folder 'C:\Windows\System32' and file 'msi.dll'
Attempting to find file 'C:\Windows\System32\msi.dll'
File version is '4.5.6000.20955'
Setting value '4.5.6000.20955 {version}' for property 'VersionMsiDll'
The following properties have been set for package 'Windows Installer 4.5':
Property: [VersionMsiDll] = 4.5.6000.20955 {version}
Running checks for command 'WindowsInstaller4_5\WindowsXP-KB942288-v3-x86.exe '
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '4.5': true
Result of checks for command 'WindowsInstaller4_5\WindowsXP-KB942288-v3-x86.exe ' is 'Bypass'
Running checks for command 'WindowsInstaller4_5\WindowsXP-KB958655-v2-x86-ENU .exe'
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsiDll' and value '4.5.6001.22299': false
Result of running operator 'ValueNotEqualTo' on property 'ProcessorArchitecture' and value 'Intel': false
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionNT' and value '5.2.0': true
Result of checks for command 'WindowsInstaller4_5\WindowsXP-KB958655-v2-x86-ENU .exe' is 'Bypass'
Running checks for command 'WindowsInstaller4_5\WindowsServer2003-KB942288-v4 -x86.exe'
Result of checks for command 'WindowsInstaller4_5\WindowsServer2003-KB942288-v4 -x86.exe' is 'Bypass'
Running checks for command 'WindowsInstaller4_5\WindowsServer2003-KB958655-v2 -x86-ENU.exe'
Result of running operator 'VersionLessThan' on property 'VersionNT' and value '5.2.0': false
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionNT' and value '6.0': true
Result of checks for command 'WindowsInstaller4_5\WindowsServer2003-KB958655-v2 -x86-ENU.exe' is 'Bypass'
Running checks for command 'WindowsInstaller4_5\WindowsServer2003-KB942288-v4 -x64.exe'
Result of checks for command 'WindowsInstaller4_5\WindowsServer2003-KB942288-v4 -x64.exe' is 'Bypass'
Running checks for command 'WindowsInstaller4_5\WindowsServer2003.WindowsXP-K B958655-v2-x64-ENU.exe'
Result of running operator 'ValueNotEqualTo' on property 'ProcessorArchitecture' and value 'amd64': true
Result of checks for command 'WindowsInstaller4_5\WindowsServer2003.WindowsXP-K B958655-v2-x64-ENU.exe' is 'Bypass'
Running checks for command 'WindowsInstaller4_5\Windows6.0-KB958655-v2-x86.MS U'
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsiDll' and value '4.5.6001.22308': false
Result of running operator 'VersionLessThan' on property 'VersionNT' and value '6.0': false
Result of running operator 'ValueExists' on property 'Version9x': false
Result of running operator 'ValueEqualTo' on property 'AdminUser' and value 'false': false
Result of checks for command 'WindowsInstaller4_5\Windows6.0-KB958655-v2-x86.MS U' is 'Install'
Running checks for command 'WindowsInstaller4_5\Windows6.0-KB958655-v2-x64.MS U'
Result of checks for command 'WindowsInstaller4_5\Windows6.0-KB958655-v2-x64.MS U' is 'Bypass'
'Windows Installer 4.5' RunCheck result: Install Needed
Running checks for package 'Microsoft .NET Framework 4 (x86 and x64)', phase BuildList
Reading value 'Version' of registry key 'HKLM\Software\Microsoft\NET Framework Setup\NDP\v4\Full'
Read string value '4.0.30319'
Setting value '4.0.30319 {string}' for property 'DotNet40Full_TargetVersion'
The following properties have been set for package 'Microsoft .NET Framework 4 (x86 and x64)':
Property: [DotNet40Full_TargetVersion] = 4.0.30319 {string}
Running checks for command 'DotNetFX40\dotNetFx40_Full_x86_x64.exe'
Result of running operator 'ValueEqualTo' on property 'InstallMode' and value 'HomeSite': true
Result of checks for command 'DotNetFX40\dotNetFx40_Full_x86_x64.exe' is 'Bypass'
Running checks for command 'DotNetFX40\dotNetFx40_Full_setup.exe'
Result of running operator 'ValueNotEqualTo' on property 'InstallMode' and value 'HomeSite': false
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'DotNet40Full_TargetVersion' and value '4.0.30129': true
Result of checks for command 'DotNetFX40\dotNetFx40_Full_setup.exe' is 'Bypass'
'Microsoft .NET Framework 4 (x86 and x64)' RunCheck result: No Install Needed
EULA for components 'Windows Installer 4.5' was accepted.
Copying files to temporary directory "C:\Users\Scymczak\AppData\Local\Temp\VSDE0F1.tmp\ "
Downloading files to "C:\Users\Scymczak\AppData\Local\Temp\VSDE0F1.tmp\ "
(12.2.2011 18:14:25) Downloading 'WindowsInstaller4_5\Windows6.0-KB958655-v2-x86.MS U' from 'fwlink' to 'C:\Users\Scymczak\AppData\Local\Temp\VSDE0F1.tmp\ '
Download completed at 12.2.2011 18:14:27
Verifying file integrity of C:\Users\Scymczak\AppData\Local\Temp\VSDE0F1.tmp\W indowsInstaller4_5\Windows6.0-KB958655-v2-x86.MSU
WinVerifyTrust returned 0
File trusted
Running checks for package 'Windows Installer 4.5', phase BeforePackage
File trusted
Installing using command 'C:\Users\Scymczak\AppData\Local\Temp\VSDE0F1.tmp\ WindowsInstaller4_5\Windows6.0-KB958655-v2-x86.MSU ' and parameters '/quiet /norestart'
Process exited with code 1
Status of package 'Windows Installer 4.5' after install is 'InstallFailed'
Asi to bude v tom, ze mi nejde nainstalovat Windows Installer 4.5, vzdycky kdyz ho chci nainstalovat z netu, napise mi, ze se ta aktualizace meho systemu netyka :(
Máš Vistu bez Service Packu, že?
