Chyba BSOD Memory Management (1a)
Dobrý den prosím o radu počítač mi zničeho nic zkolaboval do BSOD (modré obrazovky) a dělal jsem již memtest 0 chyb.(běžel 1h 30min). A tak jsem nainstaloval SDK (software development kit) a otevřel si programem "windbg" Minidump soubor a tak ho zde přikládám.Potřeboval bych poradit co s tím, čím to mohlo být. (Intel core 2 2400Mhz ; 4Gb Ram (2x2) Dual channel,750Gb HDD;ATI mobility Radeon 3650;MS Windows 7 64bit ->notebook)Zatím se mi to stalo jen 2x.Děkuji za odpovědi.
Výpis dump souboru :
* Bugcheck Analysis *
MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041289, The subtype of the bugcheck.
Arg2: 00000000775ad001
Arg3: 00000000000001b6
Arg4: 01000000775ad005
Debugging Details:
BUGCHECK_STR: 0x1a_41289
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: SearchProtocol
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff80002d2a459 to fffff80002cd5700
STACK_TEXT:
fffff880`0acdd978 fffff800`02d2a459 : 00000000`0000001a 00000000`00041289 00000000`775ad001 00000000`000001b6 : nt!KeBugCheckEx
fffff880`0acdd980 fffff800`02d07c5a : 1b600001`29130025 fffffa80`0cd0f3d0 00000000`00000011 fffff880`0acddac0 : nt! ?? ::FNODOBFM::`string'+0x49d9
fffff880`0acdd9c0 fffff800`02ca3b3e : 00000000`40470200 fffffa80`0b32c060 00000000`00000000 1b600001`29130025 : nt!MiGetPageProtection+0xaa
fffff880`0acdda00 fffff800`02ca37da : fffffa80`0cd0f3d0 fffffa80`08b1bb30 fffffa80`08b1bb30 00000000`775ad000 : nt!MiQueryAddressState+0x2ae
fffff880`0acdda50 fffff800`02fbb7c8 : fffff880`00000020 00000000`775ae000 fffffa80`0cd0f3d0 fffff880`00000000 : nt!MiQueryAddressSpan+0xaa
fffff880`0acddac0 fffff800`02cd4953 : 00000000`00000a14 fffffa80`0b32c060 fffff880`0acddbf8 00000000`044de208 : nt!NtQueryVirtualMemory+0x386
fffff880`0acddbb0 00000000`778ef8ea : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`044de1e8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x778ef8ea
STACK_COMMAND: kb
FOLLOWUP_IP:
nt! ?? ::FNODOBFM::`string'+49d9
fffff800`02d2a459 cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt! ?? ::FNODOBFM::`string'+49d9
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4d9fdd34
FAILURE_BUCKET_ID: X64_0x1a_41289_nt!_??_::FNODOBFM::_string_+49d9
Followup: MachineOwner
Připadá mi to jako chyba severního mostu. Zkusil bych notýsek vyluxovat, jestli není windtunel zanesený bordelem (přehřívání).
Základná doska
ASUSTeK Computer Inc. M51Va (Socket 478) -------> 45 °C
CPU
Intel Mobile Core 2 Duo P8600 @ 2.40GHz -------> 32 °C
HDD
733GB Western Digital WDC WD7500BPVT-22HXZT1 (SATA) ------> 36 °C
A noťase jsem čistil, profoukával a výše uvedené teploty se mi zdají naprosto normální pro chipset 45 °C je standart.
32 °C CPU bych řekl že je na své poměry ledové
i předchozí pád byl způsoben "ntkrnlmp.exe"?
a existuje příčetnější bsod viewer bez instalace, od nirsoftu.
rovnaké chyby spôsobuje nekompatibilný ovládač pre grafiku a wifi,inštaloval si ovládač zo stránok výrobcu ? asus má svoje individuálne zapojenie grafických adaptérov,na ktorom obvykle nefungujú generic ovládače priamo od ati......aké sdk si inštaloval ? nieje aktívny nekompatibilný debug_driver pre grafiku a debug_driver pre sieťové komponenty z inštalovaného SDK miesto certifikovaných final release ovládačov pre konkrétny hardware ?
Je pravda že jsem instaloval ovladače na grafiku přímo od ATI.
Ajta... Tak hybaj na stránky Asusu (či co to máš za heblo) a stáhni driver přímo pro tvůj model. A nestyď se stáhnout a nainstalovat všecky - včetně (a počínaje) chipsetem.
už jsem tak učinil .Děkuji uvidim jestli to přestane ale docela mě štve že budu mít 3 roky starej ovladač, chtěl jsem si stáhnout aktualizovanej s vylepšeníma a tak teda nic noc. Nicméně děkuji všem .
Tak tohle jsem jako neviděl
. U notesů je to trošku jinak, než u desktopových dedikovaných komponent: jestli pro tvůj NTB a OS neexistuje na stránce výrobce novější verze ovladače, buď si jist, že je stávající driver pro ten model vyladěný a jediný správný. Obecné drivery od grafiky či chipsetu ti sedět nebudou, nebo pojedou blbě - výrobci notesů nedodržují standardy ani náhodou (HW úpravy, vlastní BIOSy,...).
hm tak dik zase jsem o něco chytřejší
Tak ovladače to nebyly dělá to furt.
1) systém jsi instaloval ty? (že se vůbec ptám)
2) ostatní bsod mají stejný původ - stejný ntkrnlmp.exe? (prolez to nějakým normálním nástrojem)
Píšu zde vše co se od počátku chyb dělo a co jsem již provedl.
1) Začalo to minulý týden v úterý [Chyby BSOD IRQL not less or equal] (pův. OS : Win 7 64bit)
2) Zkoušel jsem přehodit RAMky
3) Přeinstalace Windows 7 (64 bit) (já jsem přeinstalovával)
4) Nasazení ovladačů (pro Visty 64bit) [jelikož nejsou pro win 7] ---> zde si myslím že to byla chyba i když čtěte dále
5) Vyhodilo to chybu BSOD Memory Management (výše) ; memtest -> No errors
6) Výměna harddisku za původní "Seagate 320Gb" s nainstalovanými win 7 (32bit) a ovladači (na 32bit) (dříve plně funkční)
7) Včera 26.6.2011 jsem připojil původní 750-tku disk do externího boxu že ho zformátuju (přes Ccleaner) 85% formátování -> chyba memory management,Tak jsem ho odpojil a vše se zdálo býti OK ,tak jsem si řekl jo to bylo
hardiskem ,bohužel moje nadšení neuspělo protože ve večerních hodinách (21:25) skočila chyba BSOD "An attempt was made to write to read-only memory" při spuštěném filmu, výpis možná ještě najdu, večer přidám.A ano mají stejný původ na jádro ntkrnlmp.exe.
Tak jsem včera zkusil jednu RAM vyndat a dneska to zkusím jestli to nespadne do BSOD
[BTW je to nootebook Asus M51Va :http://support.asus.com.tw/download/download.aspx? SLanguage=cs-cz]
ještě jsem teď provedl test pamětí od microsoftu a vše OK .(je pravda že jsem testoval zatim tu jednu ktera tam tedka je)
Nemáte nějaké další nápady ?
prázdný (zformátovaný a předrozdělený) disk.
nainstaluješ:
- wirdows.
- driver chipsetu, po něm vga driver (někdy jsou v jednom balíku)
- poslední servicepack
- zbylé drivery. ve správci zařízení kontroluj exotická zařízení. pokud je nebudeš potřebovat (firewire ieee1394, infraport), ani je neinstaluj, a rovnou zakaž.
- volitelně vytuníš vzhled ať se to dá používat
- aplikace (kromě správce souborů, siw, starter, vnc a pdf prohlížeče můžou počkat)
- vytuněným nastavením (bez motivu plochy) přepíšeš default usera.
stále se raduješ, že nejsou žádné chyby, žádný bsod. přesto zkontroluješ prohlížeč událostí, ať vidíš co ještě zakázat.
ztráta času. když ramkám nevěříš, boot cd a odtamtud pustit memtest nebo goldmemory.
Takže to vypadá že jsem našel konečně vadný kus a tím pádem řešení . Zkoušel jsem vyndat 1 RAM běhalo to 2dny v poho, dal jsem tam i tu druhou (byly tam 2x2Gb) při přihlašování do WIN 7 to rozmazalo obrazovku a seklo se to. Vyndal jsem tu funkční a dal jsem tam jen tu druhou.Jako zátěžový test mi posloužila Mafie II která sežrala téměř veškerou RAMku (zbylo tam jen 72mb volných) při scénce hned po 2 min hraní se to kouslo a zase rozmazáno.Vrátil jsem funkční a vše jede jak má.Takže konečně vim že to bylo RAMkou a pořídim 1 RAMku novou ,anebo případně pro podporu Dual channelu 2x2Gb KIT,uvidim.Díky všem za nápady a za pomoc (a strávený čas).
