				idFTPserver
					Mam mensi problem vse funguje az na jedno v Totalcmd , FF se nezobrazi zadna data ale pri zadani cilove adresi vse probehne OK, problem spociva v tom ze IE zobrazi vsechna data korektne nastaveni emulace je ftpsdos , pri ftpsvax nic nezobrazi a ftpslinux zobrazi data i slozky ale slozky nelze otevrit kde muze byt chyba ??
Prvni cast :
procedure TForm1.IdFTPServer1AfterUserLogin(ASender: TIdFTPServerThread);
begin
  ASender.HomeDir :=  '\';
  ASender.CurrentDir := '\';
  appdir := ExtractFilePath('f:\AppServ\generals\');
end;
procedure TForm1.IdFTPServer1UserLogin(ASender: TIdFTPServerThread;
  const AUsername, APassword: String; var AAuthenticated: Boolean);
begin
AAuthenticated := ((AUsername = 'certcv') and (APassword = 'opicak'));
  if AAuthenticated = true then
  begin
  listbox1.Items.Add(AUsername);
  end;
end;
procedure TForm1.IdFTPServer1StoreFile(ASender: TIdFTPServerThread;
  const AFileName: String; AAppend: Boolean; var VStream: TStream);
begin
  if not Aappend then
  begin
    VStream := TFileStream.Create(appdir + AFilename,fmCreate);
  end;
  if Aappend then
  begin
    VStream := TFileStream.Create(appdir + AFilename,fmOpenReadWrite);
  end;
end;
procedure TForm1.IdFTPServer1RetrieveFile(ASender: TIdFTPServerThread;
  const AFileName: String; var VStream: TStream);
begin
  VStream := TFileStream.Create(AppDir + AFilename,fmOpenRead);
  Application.ProcessMessages;
end;
procedure TForm1.IdFTPServer1ChangeDirectory(ASender: TIdFTPServerThread;
  var VDirectory: String);
begin
  Asender.CurrentDir := VDirectory;
  change_dir := VDirectory;
 VDirectory:='';
end;
procedure TForm1.IdFTPServer1ListDirectory(ASender: TIdFTPServerThread;
  const APath: String; ADirectoryListing: TIdFTPListItems);
var
 LFTPItem :TIdFTPListItem;
 SR : TSearchRec;
 SRI : Integer;
begin
  SRI := FindFirst(AppDir + change_dir + '*.*', faAnyFile - faHidden - faSysFile, SR);
  While SRI = 0 do
  begin
    LFTPItem := ADirectoryListing.Add;
    LFTPItem.FileName := SR.Name;
    LFTPItem.Size := SR.Size;
    LFTPItem.ModifiedDate := FileDateToDateTime(SR.Time);
    if SR.Attr = faDirectory then
     LFTPItem.ItemType   := ditDirectory
    else
     LFTPItem.ItemType   := ditFile;
    SRI := FindNext(SR);
  end;
  FindClose(SR);
  SetCurrentDir(AppDir + '..');
end;
procedure TForm1.Button1Click(Sender: TObject);
begin
IdFTPServer1.DefaultPort:=spinedit1.Value;
IdFTPServer1.DefaultDataPort:=spinedit1.Value-1;
IdFTPServer1.Active:=true;
end;
procedure TForm1.Button2Click(Sender: TObject);
begin
IdFTPServer1.Active:=false;
end;
procedure TForm1.IdFTPServer1Connect(AThread: TIdPeerThread);
begin
AThread.Connection.WriteLn('Vitej cerve zde muzes sosat');
end;
procedure TForm1.IdFTPServer1Disconnect(AThread: TIdPeerThread);
begin
listbox1.Items.Add(AThread.TerminatingException+'odpojen');
end;
Druha cast:
Server je spusten muzete otestovat heslo a jmeno je stejne jako ve zdrojaku.
No jo... ale kde je spusten?
certcv.com pardon zapomel jsem dopsat
Nikdo nevi ??
Nic nevím, pouze jsem jej zkoušel řádkovým NT FTP klientem, výsledek je tento:
Je mozne ze v tu dobu jsem zkousel upravu ale byla knicemu ted ho nechavam spusten trvale ale obcas se stane ze nacitany soubor je jen polovicni coz mne zarazi .
Problem jsem vyresil , predelal jsem to v Indy 10 a vse funguje jak ma.
