Nefunkční zápis do databáze MySQL
Dobrý den
Prosím Vás kde je chyba v níže psaném kodu.
Vše kromě nick name to zapisuje do databáze. Tabulka v databázy vytvořená ale nezapusije to do ní.
Poradí někdo?
<?php
Form to add a team
$confid = intval($_GET['conf']);
if ($is_admin || full_check('manage_team') || permissions_check('manage_team',$confid) ) {
$confname = getconf($confid);
$seasonname = getseasonname($confid);
print '<p><a href="' . $_SERVER['PHP_SELF'] . '">Domov</a> » <a href="' . $_SERVER['PHP_SELF'] . '?action=mainview&conf=' . $confid . '">' . $confname . ' conference</a> » Add team</p>' . "\n";
print '<h2>Pridať tým do ' . $confname . ' conference (' . $seasonname . ')</h2>' . "\n";
print "<form method=\"post\" action=\"" . $_SERVER['PHP_SELF'] . "?action=addyes\">\n";
print 'Team name: <input type="text" name="teamname" />' . "\n";
print '<br />' . "\n";
print 'Nick name: <input type="nickname" name="nickname" />' . "\n";
print 'Master team: <select name="masterteam">' . "\n";
print "\t" . '<option value="-2">-------</option>' . "\n";
print "\t" . '<option value="-1">None (Create a new one)</option>' . "\n";
$querymasterteams = 'SELECT masterteamid, masterteamname FROM sportsdb_masterteams WHERE masterteamactive = 1 ORDER BY masterteamname';
$resultmasterteams = mysql_query($querymasterteams);
while ($masterteams = mysql_fetch_array($resultmasterteams, MYSQL_ASSOC)) {
$masterteamname = htmlspecialchars($masterteams['masterteamname'], ENT_QUOTES);
print "\t" . '<option value="' . $masterteams['masterteamid'] . '">' . $masterteamname . ' </option>' . "\n";
print "</select><br />\n";
print "Divízia: <select name=\"teamdiv\">\n";
$querydivs = "SELECT divid, divname FROM sportsdb_divs WHERE conference = $confid ORDER BY divorder";
$resultdivs = mysql_query($querydivs);
while ($divs = mysql_fetch_array($resultdivs, MYSQL_ASSOC)) {
print "<option value=\"{$divs['divid']}\">{$divs['divname']}</opt ion>\n";
print "<input type=\"hidden\" name=\"confid\" value=\"$confid\" />\n";
print "<input type=\"submit\" value=\"Add\" />\n";
print "</form>\n";
print '<form method="get" action="' . $_SERVER['PHP_SELF'] . "\">\n";
print "<input type=\"hidden\" name=\"action\" value=\"mainview\" />\n";
print "<input type=\"hidden\" name=\"conf\" value=\"$confid\" />\n";
print "<input type=\"submit\" value=\"Cancel\" />\n";
print "</form>\n";
else {
die($text_no_perm);
?>Doplněn tag CODE.
Změna předmětu, původně: Nefunkční zápis do databáze. (host)
A co to je za kód? Kdo ho psal? Chybí ta část, kde se údaje zapisují do DB (INSERT, příp. UPDATE).
Díky za radu. Už jsem to upravil v jiném souboru a už vesele zapisuje.
ja uz som databazy nevidel asi 4 roky, ale nejak mi tam chyba command, ktory by nieco do DB zapisoval - ty tam mas iba SELECTy
