modra obrazovka pri vypalovani dvd
Dobry vecer,mam prosim problem.
Na mem notebooku Acer Extensa 5220,windows xp profesional mi zacala naskakovat pri zahajeni vypalovani dvd modra obrazovka s hlasenim chyb.Zkousela jsem i obnoveni systemu do jineho datumu,ale to mi jiz take nejde,pc mam i zkontrolovany na viry a je cisty.
Nevite prosim cim by to mohlo byt?
Dekuji Monika
prohlížeč událostí (eventvwr.msc) - systém nebo aplikace: tam by chyby z těch modrých obrazovek mohly být uloženy.
na analýzy bsod je taky doporučován: whocrashed
Dekuji za odpoved a snahu.Ten 1 odkaz na prohlizec udalosti mi nesel,tak jsem si stahla tu 2 variantu.
Nejsem profik na PC a tak vam napisu co mi vyjelo.Snad z toho neco vyctete.
System Information (local)
computer name: DAVID-089DCF1A0
windows version: Windows XP Service Pack 3, 5.1, build: 2600
windows dir: C:\WINDOWS
CPU: GenuineIntel Intel(R) Celeron(R) CPU 550 @ 2.00GHz Intel586, level: 6
1 logical processors, active mask: 1
RAM: 2137374720 total
VM: 2147352576, free: 2032775168
Crash Dump Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Wed 29.2.2012 15:25:50 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini022912-01.dmp
This was probably caused by the following module: usbport.sys (USBPORT+0xA1A1)
Bugcheck code: 0x100000C5 (0x9EB10, 0x2, 0x0, 0xFFFFFFFF805446B2)
Error: CUSTOM_ERROR
file path: C:\WINDOWS\system32\drivers\usbport.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: USB 1.1 & 2.0 Port Driver
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Sat 25.2.2012 20:42:40 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini022512-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x4BBBE)
Bugcheck code: 0x10000050 (0xFFFFFFFFFFFFFFEC, 0x1, 0xFFFFFFFF80522BBE, 0x0)
Error: CUSTOM_ERROR
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Operační systém Microsoft® Windows®
description: NT Kernel & System
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
Conclusion
2 crash dumps have been found and analyzed.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
