Modrá smrt - neustaly problem - restarty PC
A problem has been detect and Windows has been shut down to prevent demage
to your computer.
DRIVER_IRQL_NOT_LESS_OR_EQUAL
If this is the first time you´ve seen thus stop error screen,
restard your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If thus is a new instalation, ask your hardware or software manufacturer
for any windows updates your might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use Safe Mode to remove or disable components, restart,
your computer, press F8 to select Advenced Startup Options, and then
select Safe Mode.
Technical information:
*** STOP: 0x000000D1 (0x019FFFFF,0x00000002,0x00000000,0x8908713A)
*** tcpip.sys - Address 8908713A base at 89002000, Date Stamp 4a5bbf8e
Collecting data for crash dump ...
Initializing disk for crash dump ...
Beginning dump of psysical memory.
Dumping physical memory to disk: 100
Physical memory dump complete.
Contact your system admin or technical support group for further assistance.
______________
to your computer.
these steps:
select Safe Mode.
*** STOP: 0x0000000A (0xC55DDCBC,0x00000002,0x00000001,0x82C3F0E9)
______________
Tyhle modré obrazovky pořád naskakují, pc jede tak 3 minuty a potom nahodí tenhle
problém. Nevíte nekdo co s tím?. Budu strašne rád za pomoc, na pc pracuju a strasne
ho potřebuju.
OS: Windows 7 32bit, deska: Gigabyte GA-M56S-S3, Ram: DDRII 2gb, CPU: AMD Athlon 4 X2 Dual Core 4400 2.30GHz
HDD: Barracuda 160gb, Zdroj: Forton 400W, Grafika: ATi Raedon HD 2600XT 256Mb DDRII
Mas virus instalacia windowsu
Takže mě zachraní jedine reinstal os?
Ano nic ine
oukej tak ja tedy dekuju:) i kdyz me to ted strasne nas*ralo! :D
Neda sa nic ine urobit
Lobotomia zjavne prebehla v poriadku.
hej počkaj, debil si z teba robi srandu, nevidiš že to je jablko?
máš tam problém s ovládačom, vraj by na tuto chybu mala existovat zaplata tak skus si skontrolovat windows update
Citaj poriadne ako si moze skontrolovat update ked ma restart a oblohu toto my vysvetli
memtest?
nouzovy rezim?
prohlizec udalosti?
msconfig a zakazat vsechno co se spousti a neni to od MS?
spravce zarizeni - nejake vykricniky?
Edit:
update ovladace sitove karty?
Problem je že na tu moji desku nejsou ovladače na WIN7 32bit
to myslis vazne nebo si delas srandu?
vymen OS za nejaky na ktery jsou ovladace nebo vymen desku, pripadne jestli sjou ovladace pro Vista 32bit, tak zkus ty.
vic neni co resit.
Ako pise Redmarx ...
Skus ovladace na Vistu 32bit. Ak nepojdu, tak tam vrat to, co tam bolo predtym (Vista, XP).
Vedome si nainstaloval OS na ktory nemas ovladace, co si cakal?
Hele mě to dělalo taky hrál jsem hru a po 5 minutách hraní BLUESCREEN furt mi padali prohlížeče atd. tak jsem vyčistil pc a nakonec jsem zjistil že to dělá jedna z RAM. Tu 512 mb jsem vyndal a dal tam jinou 512 MB a už to zase běží
tak to zkus
proč ne. ale důvod pádu do bsod bývá často zachycen v prohlížeči událostí - tam by měl začít jak tazatel, tak kdejaký radil.
