Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem Problém s mp3tagem
Zdravím,
mám problém s programem mp3tag.
Tvořím si přes něj offline stránky kde mám seznam hudby.
Tvoří ho soubor s tímto kodem:
$filename(html,utf-8)<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
<html xmlns="www.w3.org/1999/xhtml" xml:lang="de">
<head>
	<meta name="GENERATOR" content="Mp3tag - www.mp3tag.de" />
	<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
	<title>Mp3tag - File Overview</title>
	<style type="text/css"><!--
		h1 { font-family: Verdana, Tahoma, Arial, sans-serif; font-size: 14pt; color: #960000 }
		body { font-family: Verdana, Tahoma, Arial, sans-serif; font-size: 8pt; background: #f90 }
		table, tr, td { font-family: Verdana, Tahoma, Arial, sans-serif; font-size: 9pt; color: #000; }
		a:link, a:visited, a:active { text-decoration: none; color: #03f; }
		a:hover { text-decoration: none; color: #f03; }
		.title { font-weight: bold; padding: 7px; margin: 0px; color: #960000; }
		.odd { background-color: #fc0; }
.okno {display: none}
	--></style>
<script>
function zobrazSkryj(idelementu){
el=document.getElementById(idelementu).style;
el.display=(el.display == 'block')?'none':'block';}
</script><style type="text/css">
body {
margin:0;
padding:0;
--></style>
</head>
<body>
 <img width="100" height="100" src="file:///%_folderpath%/%album%.jpg">
 <img width="100" height="100" src="file:///%_folderpath%/X.jpg">
 <img width="100" height="100" src="file:///%_folderpath%/Y.jpg">
 <img width="100" height="100" src="file:///%_folderpath%/Z.jpg">
<h1 onclick="zobrazSkryj('textik')">(%year%)    //    %album%</div></h1>  </div>
 <h3$if($odd(%_counter%), class="odd",)>$replace(%albumartist%,&,&amp;)</h3>
<div id="textik" class="okno">
	<table>
		<tr>
			<th class="title">Track</th>
			<th class="title">Title</th>
			<th class="title">Artist</th>
			<th class="title">Genre</th>
                                                        <th class="title">Composer</th>
			<th class="title">Lenght</th>
			<th class="title">Filename</th>
		</tr>
$loop(%_filename_ext%)
		<tr>
			<td$if($odd(%_counter%), class="odd",)>$replace(%track%,&,&amp;)</td>
			<td$if($odd(%_counter%), class="odd",)>$replace(%title%,&,&amp;)</td>
			<td$if($odd(%_counter%), class="odd",)>$replace(%artist%,&,&amp;)</td>
			<td$if($odd(%_counter%), class="odd",)>$replace(%genre%,&,&amp;)</td>
                                                        <td$if($odd(%_counter%), class="odd",)>$replace(%composer%,&,&amp;)</td>
			<td$if($odd(%_counter%), class="odd",)>$replace(%_length%,&,&amp;)</td>
			<td$if($odd(%_counter%), class="odd",)>$replace(%_filename_ext%,&,&amp;)</td>
		</tr>
$loopend()
	</table>
<h3>Vydavatel:     %publisher%</h3> </span>
<h1>""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""</h1></div>
</body>
</html>
Problém je v tom že ruší ' tudíž pak nefunguje ten script co jse tam přidal na rozklikávání albumů.
Nemáte někdo zkušenosti s tímto programem a radu jak vyřešit tento problém aby mi nerušil '
Změníš ' za &apos;
Wikan 08.04.2012 20:25
zkusím Edit: Tak to nefunguje pokud tam dám &apos; tak to ve finále neudělá onu zmíněnou ' ale napí…
Gizzer 08.04.2012 20:34
Gizzer
A jakým způsobem to měníš?
Wikan 08.04.2012 20:51
Například toto: <h1 onclick="zobrazSkryj('textik')"> měním za toto <h1 onclick="zobrazSkryj(&apos…
Gizzer 08.04.2012 21:56
Gizzer
Aha, to jsem špatně pochopil, v čem máš vlastně problém. Zkus tohle: <h1 onclick="zobrazSkryj('text…
Wikan 08.04.2012 22:03
Mám problém s tím že mi ten program mp3tag podle toho kodu dělá html mých skladeb. Kod co jsem se da…
Gizzer 08.04.2012 22:05
Gizzer
No počkej, kde ti je teda vyrušuje?
Wikan 08.04.2012 22:07
Už potom v hotovým HTML. Tohle co jsem sem dal je kod na tvorbu html v tom mp3tagu. Přidal jsem tam… poslední
Gizzer 08.04.2012 22:15
Gizzer
OT: nechápu, proč vůbec mp3 tagy… Hudbu skladuji v adresářích. Písmeno - název interpreta - (rok vy…
L-Core 08.04.2012 20:49
L-Core
Kod co jsem se dal je zdrojový kod podle kterého to ten mp3tag dělá. Ale problém je právě to že mi vyrušuje ty ' Myslím ale že pro toto rada není.
I tak díky moc.
Přidal jsem tam script na schování a zobrazení textu, který obsahuje ' Když ti projde tím mp3tagem a vytvoří se html soubo rkterý už obsahuje informace o hudbě tak tam jsou už ty ' smazány a tím pádem script je nefunkční.
Hudbu skladuji v adresářích. Písmeno - název interpreta - (rok vydání) název alba - název skladby. Nikdy jsem nějaký tag nepotřeboval (naopak, pro mě zbytečné tagy mažu). Používám Foobar 2000 v enhanced verzi 0.8.3 (poslední verze, která bezchybně zvládá - v naprosté většině případů - gap killer).
