zablokování sociální sítě
Dobrý den prosím Vás jak zablokuji např. Facebook.com na pc ? Aby se mi ta stránka už vůbec nedala zobrazit ani na ni jít ? Děkuji . !
upravenim host soubporu nebo FW nebo konfiguraci routeru,...
navic zablokovat facebook.com nestaci, tech serveru je vice
facebook.com
facebook.net
fbcdn.net
(to mám ve filtru AdBlocku, možná jsou i další)
abys ho skutecne utnul, musis tam mit:
# BLOKOVÁNÍ FACEBOOKU
127.0.0.1 www.facebook.com
127.0.0.1 facebook.com
127.0.0.1 static.ak.fbcdn.net
127.0.0.1 www.static.ak.fbcdn.net
127.0.0.1 login.facebook.com
127.0.0.1 www.login.facebook.com
127.0.0.1 fbcdn.net
127.0.0.1 www.fbcdn.net
127.0.0.1 fbcdn.com
127.0.0.1 www.fbcdn.com
127.0.0.1 static.ak.connect.facebook.com
127.0.0.1 www.static.ak.connect.facebook.com
#pro ipv6
::1 www.facebook.com
::1 facebook.com
::1 static.ak.fbcdn.net
::1 www.static.ak.fbcdn.net
::1 login.facebook.com
::1 www.login.facebook.com
::1 fbcdn.net
::1 www.fbcdn.net
::1 fbcdn.com
::1 static.ak.connect.facebook.com
::1 www.static.ak.connect.facebook.com
proč máš tu adresu 2x ? ale i tak bod za snahu. hosts zklamal, že nedokáže blokovat adresy hierarchicky, a musí se všechny varianty vypsat.
ZADALA JSEM TO TAKTO ,ALE I PŘESTO MI TO STÁLE TU STRÁNKU NALEZNE . jE NA TOM NĚCO ŠPATNĚ ?POKUD ANO PROSÍM PORADTE ' !
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handled within DNS itself.
# 127.0.0.1 localhost
# ::1 localhost
::1 facebook.com
::1 fbcdn.net
::1 www.fbcdn.net
::1 fbcdn.com
To ze si mas zablokovat pristup na Facebook ti poradil kto, tvoj doktor?
Ty máš snad IPv6?
A stále mi to lze otevřít .
Tak si to urobil blbo. A my vobec nevieme co si urobil a jak, tak ti nemozme povedat co si urobil blbo.
zKOUŠELA JSEM TO I TAKTO :
# space.
# For example:
# ::1 localhost
127.0.0.1 fbcdn.net
127.0.0.1 fbcdn.com
A napisal si to kam?
A ked ti tam navrchu napisal toho 2x tolko tak preco do toho suboru hosts kopirujes len polovicu?
DO hosts . Jak polovičku : ? pomalý vedení :D
Aj ked to tam vlozim cele . stale sa mi to otvara ?
skus restartnut PC, ci sa ti to bude otvarat aj potom
Co tam mam tedy presne zadat ? Jsem z toho pekně zmatená .
to co ti napisal ms-fiala a potom restartni PC (alebo aspon prehliadac, to by mohlo stacit)
Ak subor editujes v notepade (Poznamkovy blok), daj pozor ci Ti notepad nepridal priponu TXT (host.txt system ignoruje).
obojí ? tam mám dát ? Ano je tam hosts.txt
tak logicky odmaz koncovku txt
nejde to .
Takze otvorila si subor "host" upravila a ulozila ako subor "host.txt"
Povodny "host" sa nezmenil ale sa pridal "host.txt", ktory system ignoruje. Preto ziadna zmena.
Vymaz suboru "host.txt" priponu.
už to je.
Mas jedno chladene
co nejde a co uz je? vies, odtialto nevidime co robis, musis to popisat detailnejsie.
restartovala jsem to a stále to nejde :X
Vlož sem jako přílohu daný "HOSTS" soubor ať to můžeme zkontrolovat. A Prozraď jaký máš OS.
Máš ten hosts tam, kde má být? C:\Windows\System32\drivers\etc
Proto jsem se ptal na OS, radeji vlozim obrazek.
![[10268-hosts-soubor-png]](/file/view/10268-hosts-soubor-png)
ať vidíš co vlastně edituješ:
ten soubor je skutečně bez koncovky (a defaut read-only), kdežto notepad mu při uložení přidá nefunkční připonu (hosts.txt)
základní uživatelé to ovšem netuší, protože: 1) mají zobrazování přípon vypnuto, 2) neumí používat normální správce souborů.
