Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem BSOD - prosím o pomoc
Zdravím, koupil jsem si nové komponenty do počítače, a po instlaci ovladačů, semi občas zažalo objevovat BSOD, zanalyzoval jsem tento soubor, ale nenašel jsem příčinu problému. Zde vám zkopíruji analýzu.
PŘEDEM DĚKUJI ZA POMOC
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\080812-12433-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Mini Kernel Dump does not have process information
Symbol search path is: symbols
Executable search path is:
Unable to load image Unknown_Module_00000000`00000000, Win32 error 0n2
*** WARNING: Unable to verify timestamp for Unknown_Module_00000000`00000000
Unable to add module at 00000000`00000000
WARNING: .reload failed, module list may be incomplete
Debugger can not determine kernel base address
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02e53000 PsLoadedModuleList = 0xfffff800`03090e50
Debug session time: Wed Aug 8 14:10:08.422 2012 (GMT+2)
System Uptime: 0 days 3:46:51.717
Loading Kernel Symbols
.Unable to load image Unknown_Module_00000000`00000000, Win32 error 0n2
Loading User Symbols
Loading unloaded module list
.Missing image name, possible paged-out or corrupt data.
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa80077cd028, be200000, 5110a}
***** Debugger could not find nt in module list, module list might be corrupt, error 0x80070057.
Probably caused by : Unknown_Image
Followup: MachineOwner
0: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa80077cd028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000be200000, High order 32-bits of the MCi_STATUS value.
Arg4: 000000000005110a, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_GenuineIntel
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
CURRENT_IRQL: 0
STACK_TEXT:
fffff800`00ba8a98 fffff800`02e1c903 : 00000000`00000124 00000000`00000000 fffffa80`077cd028 00000000`be200000 : 0xfffff800`02ec4f00
fffff800`00ba8aa0 00000000`00000124 : 00000000`00000000 fffffa80`077cd028 00000000`be200000 00000000`0005110a : 0xfffff800`02e1c903
fffff800`00ba8aa8 00000000`00000000 : fffffa80`077cd028 00000000`be200000 00000000`0005110a fffffa80`07874010 : <Unloaded_Unknown_Module_00000000`00000000>+0x124
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
BUCKET_ID: CORRUPT_MODULELIST
Odkaz na soubor .bmp:
080812-12433-01-dmp
369439747
spíše než pošahané dumpy by bylo vhodnější napsat, co máš za PC (deska, zdroj, CPU, grafika, skříň),…
touchwood 08.08.2012 14:51
Moje aktuální sestava: MSI Z77A-G45 Intel Core i5-2500K Kingston HyperX Blu 8GB 1333MHz Intel 32…
Assassin 08.08.2012 15:11
Assassin
ale co si menil v HW a za co? Ak si robil nieco s RAM tak vyber tie nove moduly. Je mozne aj ze mas…
MM.. 08.08.2012 16:07
Měnil jsem základní desku, procesor, RAM, chladič procesoru. Ale vše jsem instaloval na novou kopii…
Assassin 08.08.2012 19:17
Assassin
Otestovat RAM zkoušels?
karel 08.08.2012 19:23
Zkoušel jsem celkový stress test přes AIDA64 a vše v pořádku, akorát se grafika dostala na 99 stupnů…
Assassin 08.08.2012 19:36
Assassin
Takže nezkoušel.
karel 08.08.2012 19:37
Takže jak je mám prosím tě vyzkoušet?
Assassin 08.08.2012 19:39
Assassin
memtest86
touchwood 08.08.2012 19:40
Okrem toho testu RAM (napr. goldmemory.cz stiahnut iso vypalit na CD nabootovat, alebo UBCD a tam je…
MM.. 08.08.2012 19:42
http://msdn.microsoft.com/en-us/library/windows/ha rdware/ff557321(v=vs.85).aspx Důležité tam je as…
IQ37 08.08.2012 15:41
Bohužel Windows Update používat nemůžu. Že by se ani né za jeden den dostaly do počítače viry? Jak…
Assassin 08.08.2012 15:50
Assassin
Bohužel Windows Update používat nemůžu. v tom případě reklamujte operační systém tam, kde jste ho k…
jirka44 08.08.2012 16:07
jirka44
Tohle jsou dost katastrofální odpovědi: - asi nemáš legální OS - viry se do PC dostanou během okamž…
IQ37 08.08.2012 20:00
Legální systém nemám, uvažuji o koupi. Test v ESETU dopadl dobře, bez nákazy. Kontrola disku bez pro…
Assassin 08.08.2012 20:09
Assassin
Ked si mal stejny problem aj predtym tak je problem v tom co si nevymenil :) Zdroj? Instalacku Win?…
MM.. 08.08.2012 20:12
A najprv musis vymenit HW a az potom instalovat Windows (na novom HW), ne naopak. (tym narazam na to…
MM.. 08.08.2012 20:13
Samozřejmě jsem měnil nejprve HW, potom až jsem instaloval systém :-) Neměnil jsem pouze zdroj, GK,…
Assassin 08.08.2012 20:43
Assassin
unknown_module_00000000`00000000.sys nemá cenu dělat pochybné výkonové testy hw, když ti pc nejede… poslední
lední brtník 08.08.2012 21:38
spíše než pošahané dumpy by bylo vhodnější napsat, co máš za PC (deska, zdroj, CPU, grafika, skříň), co jsi vyměnil a za co. Dále pak, co jsi instaloval za ovladače atd.
MSI Z77A-G45
Intel Core i5-2500K
Intel 320 series High Performance 2.5" 40GB + 1TB Samsung
Seasonic M12II-520 520W Bronze
MSI N560GTX-Ti Twin Frozr II/OC
Všechny ovladače ZD (chipset, SATA, zvukovka atd atd atd), grafická karta (aktuální z webu výrobce) jsem instaloval na novou kopii Windows 7 64x.
Teploty sleduju přes CPUID Monitor: Procesor idle 40, v IntelBurnTestV2 max 65.
Grafika idle 40, burn 70.
Okrem toho testu RAM (napr. goldmemory.cz stiahnut iso vypalit na CD nabootovat, alebo UBCD a tam je memtest86+) este by som skusil pozicat od kohokolvek si original instalacku Win7 a nainstalovat nacisto Win z nej, nemusis to aktivovat a nemusis ani zadavat ziadne instalacne cislo (u Win7) a mozes to 30dni pouzivat na skusku (a mozes potom aj pouzivat windows update. tych 30dni samozrejme)
Důležité tam je asi toto:
Download and install updates and device drivers for your computer from Windows Update.
Scan your computer for computer viruses.
Check your hard disk for errors.
Chyba hardware, možná zapříčiněná přehřátím.
On Wed 8.8.2012 12:10:08 GMT your computer crashed
crash dump file: C:\Windows\Minidump\080812-12433-01.dmp
uptime: 03:46:51
This was probably caused by the following module: unknown_module_00000000`00000000.sys (Unloaded_Unknown_Module_00000000`00000000+0x124)
Bugcheck code: 0x124 (0x0, 0xFFFFFA80077CD028, 0xBE200000, 0x5110A)
Error: WHEA_UNCORRECTABLE_ERROR
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: unknown_module_00000000`00000000.sys .
Google query: unknown_module_00000000`00000000.sys WHEA_UNCORRECTABLE_ERROR
- viry se do PC dostanou během okamžiku
- pokud neumíš spustit kontrolu disku anebo použít nějakou externí utilitu - je to na servis
- CPU nebo GK se přehřejí, kdykoliv nejsou dostatečně chlazené - to může být i při procházení netu, třeba se netočí ventilátor...
Co ty ovladače? Pokud můžeš, zkus jinou grafiku (anebo tu svoji v jiném PC), jestli je vadná GK.
Neměnil jsem pouze zdroj, GK, 1SSD disk a 1SATA disk. Zítra budu mít na vyzkoušení jinou grafickou kartu. Disky jsem otestoval a bez problému. Dá se něják otestovat stabilita zdroje?
Jinak jsem dělal stress test procesoru a po přetaktování na 4200 MhZ a typloty šly max. na 65 stupňů.
Na té analýze mě ale zarazil jeden řádek, nebude problém v ovladačích? Ale v jakých? :-/
nemá cenu dělat pochybné výkonové testy hw, když ti pc nejede normálně.
spusť už konečně ten memtest.
tobě to padá jen při výkonové zátěži? zdroj je nějaký starý, obskurní značky?
tvůj kradený systém si zkontroluj nějakým na windows nezávislým antivirovým boot cd.
a pokud máš novější základní desku, do windows si konečně doinstaluj driver jejího chipsetu.
