Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem Steam a občiansky preukaz
Už som tu o tom písal, mal som problém so Steam-om že som si dobil steam peňaženku v ČR a keď som prišiel naspäť na Slovensko tak mi nefungovali pladby. Napísal som na Steam Support a oni mi odpísali toto:
(v skratke - je tam že mi prenastavia účet aby som mohol platiť aj na Slovensku, ale pre finančné a daňové dôvody si potrebujú overiť či žijem v tej krajine a potrebujú kópiu občianskeho preukazu.)
Hello,
A staff member has replied to your question:
Hello 12345,
Thank you for contacting Steam Support.
We can change the currency for your future purchases. However, for financial and tax reasons, we must confirm that you are currently living in the country you've moved to before we can switch the currency. Please scan a copy of your driver's license or ID card and attach it to this ticket. As soon as we have that information we will be able to convert your account's default currency.
Thank you for your understanding and patience with this issue.
Please follow these instructions to upload images to your support ticket:
1) Log in to your support account
2) Navigate to the 'Ask a Question' tab (where you would normally write your support tickets)
3) To attach a photo to your ticket, navigate to 'You May Upload an Attachment' (underneath the text entry field)
4) Click 'Add Attachment' to reveal the uploading interface
5) Click on the 'Browse' button to locate the file on your computer
6) Once you have located the file, select it in the browser window and click 'Open'
[NOTE: At this point, if you need to upload more than one image, you may do so by following steps 3 through 6]
7) Submit your ticket, once you have finished attaching the required images
If you have any further questions, please write back to us.
Mám to urobiť? Nerád by som dával na net občiansky, predsa len sú tam údaje čo sa dajú zneužiť, ale nerád by som aby mi nechali bloknutý ten účet, mám tam ešte okolo 40 €.
Zneužít se dá IMHO jen číslo (možná rodné číslo), nic ti nebrání část informací rozmazat nebo vyřízn…
touchwood 23.08.2012 06:52
Preboha ty nechavas kopiu obcianskeho na kazdom urade a pomaly v kazdej druhej firme, kde maju vratn…
fleg 23.08.2012 08:15
fleg
Nevím k čemu jim ta kopie řidičáku nebo občanky bude. Nebo si mám myslet, že mají přístup do databáz…
IQ37 23.08.2012 08:27
oni potrebujú overiť miesto trvalého pobytu,resp.štátnu príslušnosť,do žiadnej databázy prístup nema…
audax 23.08.2012 13:54
audax
Nedovedu si představit, že přijdu do banky s nějakým papírem, na kterém je oskenovaný průkaz a oni m… poslední
IQ37 23.08.2012 18:46
Ďakujem tak to teda urobím, a len pre poriadok či som to správne pochopil - na Steam Support otvorím…
12345 23.08.2012 12:47
12345
Zneužít se dá IMHO jen číslo (možná rodné číslo), nic ti nebrání část informací rozmazat nebo vyříznout.
P.S.:
máš možnost poslat fotku řidičáku, tam žádné zásadní informace nejsou.
Nevím k čemu jim ta kopie řidičáku nebo občanky bude. Nebo si mám myslet, že mají přístup do databáze řidičáků a občanek v ČR (SR), aby si to mohli ověřit? V tom případě bych opravdu obavy měl.
oni potrebujú overiť miesto trvalého pobytu,resp.štátnu príslušnosť,do žiadnej databázy prístup nemajú,len potrebujú overiť,že si občan toho štátu,ktorý deklaruješ v prihlasovacích údajoch,v amerike a mnohých iných miestach neexistujú občianske preukazy ale totožnosť sa preukazuje vodičákom,preukazom zdravotného poistenia , pasom,rodným listom,výpisom z matriky alebo identifikačnou kartou,ktorú vydáva cudzinecká polícia,pokial sa tam človek prisťahuje na prechodný alebo trvalý pobyt,takže preto žiadajú predloženie prefoteného dokladu totožnosti/u nich na prvom mieste vodičáku/ alebo nejakej identifikačnej karty/,z ktorého je jednoznačne vyčítatelné,že napr.Jozef Opršálek = Česká alebo Slovenská Republika,na nič iné to nepotrebujú,zneužiť sa dá všetko,to je zasa pohlad na problém z druhej strany....
Nedovedu si představit, že přijdu do banky s nějakým papírem, na kterém je oskenovaný průkaz a oni mi půjčí třeba 1 korunu... Proto jsem vyjádřil podiv, k čemu a jak někomu takové "potvrzení" identity může stačit.
