program WinDbg hlásí chybu
Zdravím.
Potřeboval bych poradit s programem WinDbg, snažím se analyzovat BSOD, ale nějak mi to nejde, bohužel neumím anglicky a WinDbg zase česky. Když dám Open crash dump, a následně príkaz "analyze -v", tak mi vyleze toto:
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\100912-25942-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17803.x86fre.win7sp1_gdr.120330-1504
Machine Name:
Kernel base = 0x83252000 PsLoadedModuleList = 0x8339b4d0
Debug session time: Tue Oct 9 01:02:15.480 2012 (GMT+1)
System Uptime: 0 days 0:00:23.649
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
0: kd> analyze -v
*** WARNING: Unable to verify timestamp for nvstor.sys
*** ERROR: Module load completed but symbols could not be loaded for nvstor.sys
*** WARNING: Unable to verify timestamp for amdxata.sys
*** ERROR: Module load completed but symbols could not be loaded for amdxata.sys
*** WARNING: Unable to verify timestamp for MpFilter.sys
*** ERROR: Module load completed but symbols could not be loaded for MpFilter.sys
*** WARNING: Unable to verify timestamp for spldr.sys
*** ERROR: Module load completed but symbols could not be loaded for spldr.sys
*** WARNING: Unable to verify timestamp for dump_nvstor.sys
*** ERROR: Module load completed but symbols could not be loaded for dump_nvstor.sys
*** WARNING: Unable to verify timestamp for dtsoftbus01.sys
*** ERROR: Module load completed but symbols could not be loaded for dtsoftbus01.sys
*** WARNING: Unable to verify timestamp for wfcxacap.sys
*** ERROR: Module load completed but symbols could not be loaded for wfcxacap.sys
*** WARNING: Unable to verify timestamp for intelppm.sys
*** ERROR: Module load completed but symbols could not be loaded for intelppm.sys
*** WARNING: Unable to verify timestamp for wfcxvcap.sys
*** ERROR: Module load completed but symbols could not be loaded for wfcxvcap.sys
*** WARNING: Unable to verify timestamp for hidusb.sys
*** ERROR: Module load completed but symbols could not be loaded for hidusb.sys
*** WARNING: Unable to verify timestamp for yk62x86.sys
*** ERROR: Module load completed but symbols could not be loaded for yk62x86.sys
*** WARNING: Unable to verify timestamp for ASACPI.sys
*** ERROR: Module load completed but symbols could not be loaded for ASACPI.sys
*** WARNING: Unable to verify timestamp for wfcxxbar.sys
*** ERROR: Module load completed but symbols could not be loaded for wfcxxbar.sys
*** WARNING: Unable to verify timestamp for wfcxatun.sys
*** ERROR: Module load completed but symbols could not be loaded for wfcxatun.sys
*** WARNING: Unable to verify timestamp for wfcxdtun.sys
*** ERROR: Module load completed but symbols could not be loaded for wfcxdtun.sys
*** WARNING: Unable to verify timestamp for nvhda32v.sys
*** ERROR: Module load completed but symbols could not be loaded for nvhda32v.sys
*** WARNING: Unable to verify timestamp for drmk.sys
*** ERROR: Module load completed but symbols could not be loaded for drmk.sys
*** WARNING: Unable to verify timestamp for ADIHdAud.sys
*** ERROR: Module load completed but symbols could not be loaded for ADIHdAud.sys
*** WARNING: Unable to verify timestamp for wfcxtcap.sys
*** ERROR: Module load completed but symbols could not be loaded for wfcxtcap.sys
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
*** WARNING: Unable to verify timestamp for ULCDRHlp.sys
*** ERROR: Module load completed but symbols could not be loaded for ULCDRHlp.sys
*** WARNING: Unable to verify timestamp for TSDDD.dll
*** ERROR: Module load completed but symbols could not be loaded for TSDDD.dll
Couldn't resolve error at 'nalyze -v'
Díky
Snad stačí podívat se v BlueScreenView na caused by driver. Řeš ty BSOD a ne to, jak zacházet s programem v angličtině.
To bych právě moc rád, ale to co mi píšeš, tak neznám. Zkusím to. Problém je, že se mi PC každou chvíli kousne, a bud musím restart, nebo samo hodí BSOD, zkoušel jsem měnit ramky, grafiku, a zatím nemůžu přijít na to, co to dělá.
tak jsem spustil ten program, cos mi poradil, ale bohužel nevím jak s ním pracovat, taky angličtina. nemohl bys mi prosím poradit?
Přečíst, napsat to do Google, hledat řešení. Obávám se, že to bude většinou anglicky, snad pomůže Google Translate.
ale když se nad tím zamyslím, tak se mi nezdá, že by to dělal nějaký Win. ovladač, protože mi PC kolikrát zamrzne při POST testech, nebo v BIOSu.
ulcdrhlp.sys.html
no stejně z toho nejsem moudrej, tohle mi to vypsalo:
