Chyba certifikátu
Cau lidi, mam problem ze dne na den mi zacalo pri nacitani Drakensang online psat:"Failed to valide certificate. The application will not be executed. A kdyz dam detaily tak se v Java Conocle napise toto:
Match: digest selected JREDesc: JREDesc[version 1.6+, heap=-1--1, args=null, href=j2se, sel=false, null, null], JREInfo: JREInfo for index 0:
platform is: 1.7
product is: 1.7.0_09
location is: j2se
path is: C:\Program Files\Java\jre7\bin\javaw.exe
args is: null
native platform is: Windows, x86 [ x86, 32bit ]
JavaFX runtime is: JavaFX 2.2.3 found at C:\Program Files\Java\jre7\
enabled is: true
registered is: true
system is: true
Match: ignoring maxHeap: -1
Match: ignoring InitHeap: -1
Match: digesting vmargs: null
Match: digested vmargs: [JVMParameters: isSecure: true, args: ]
Match: JVM args after accumulation: [JVMParameters: isSecure: true, args: ]
Match: digest LaunchDesc: win32_7.jnlp
Match: digest properties: []
Match: JVM args: [JVMParameters: isSecure: true, args: ]
Match: endTraversal ..
Match: JVM args final:
Match: Running JREInfo Version match: 1.7.0.09 == 1.7.0.09
Match: Running JVM args match: have:<> satisfy want:<>
CacheEntry[assured-cs-2011a.crl]: updateAvailable=true,lastModified=Tue Oct 23 19:40:02 CEST 2012,length=3733
CacheEntry[assured-cs-2011a.crl]: updateAvailable=true,lastModified=Mon Oct 29 18:40:02 CET 2012,length=3733
Java Plug-in 10.9.2.05
Using JRE version 1.7.0_09-b05 Java HotSpot(TM) Client VM
User home directory = C:\Users\Predator
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
Sorry, preklep Java Console.
Jaj, venuje se tomu nekdo prosim?
Mas v PC nastaveny spravny datum?
Ak ano tak moezs skusit vliezt do ovladacie panely - java, a tam dat vymazat vsetky docasne subory (cache), a data aplikacii.
