exim MTA problem s autentifikaciou
Zdravim,
Nevie mi niekto povedat kde moze byt zrada, ked pri odosielani mailu z lokalneho servera na iny lokalny server dojde k nasledovnej chybe:
2012-11-14 11:58:03 1TYafM-0007k9-1K TLS error on connection to mail.test.local [192.168.0.1] (recv): A TLS packet with unexpected length was received.
2012-11-14 11:58:03 1TYafM-0007k9-1K TLS error on connection to mail.test.local [192.168.0.1] (send): The specified session has been invalidated for some reason.
2012-11-14 11:58:03 1TYafM-0007k9-1K ** test@test.local R=dnslookup_relay_to_domains T=remote_smtp: SMTP error from remote mail server after MAIL FROM:<root@mail.test1.local> SIZE=1515: host mail.test.local [192.168.0.1]: 530 5.7.1 Client was not authenticated
Parametre serverov:
mail.test.local - Exchange server 2010 - realna prevadzka funguje korektne
mail.test1.local - Ubuntu exim4 - testovaci server
Neviem prist na to kde je chyba. Ci tam treba certifikat pridat, alebo kde je vlastne zrada. Mam este jeden Ubuntu server kde je konfiguracia exim4 servera rovnaka ako na mail.test1.local a odosielanie mailov tam funguje aj na Exchange. Rozdiel je len v tom, ze mail.test1.local je okliestena verzia ubuntu pre virtual a ten dalsi ubuntu server je plna instalacia s CD - nie virtual.
Za kazdu odpoved vopred dakuje
perdo
No podla chyby neprijima mailserver z linuxu certifikat z okien, otazka znie preco. Skus rozsirit logovanie na vyssi level na linuxe nech sa dozvieme viac.
