Pomoc s instalací hry na Linux
Zdravím, možná blbý dotaz, ale pokouším se nainstalovat Call of duty 4 na můj linux, ale pořád mi to nejede. Dělám to přes Playonlinux ale když dám do terminálu glxinfo ukáže mi to tohle....Pomůžete mi? Je to odkaz na to jestli jede grafická karta jak má, instaloval jsem podobně microsoft office, ale už nevím jak jsem to přes ten play on linux udělal.
nicco@Nicco ~ $ glxinfo
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGI_swap_control, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX_INTEL_swap_event
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_get_proc_address,
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_EXT_framebuffer_sRGB,
GLX_EXT_create_context_es2_profile, GLX_MESA_copy_sub_buffer,
GLX_MESA_multithread_makecurrent, GLX_MESA_swap_control,
GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample,
GLX_EXT_texture_from_pixmap, GLX_INTEL_swap_event
GLX version: 1.4
GLX extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Mobile Intel® GM45 Express Chipset
OpenGL version string: 2.1 Mesa 9.0-devel
OpenGL shading language version string: 1.20
OpenGL extensions:
GL_ARB_multisample, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_copy_texture,
GL_EXT_polygon_offset, GL_EXT_subtexture, GL_EXT_texture_object,
GL_EXT_vertex_array, GL_EXT_compiled_vertex_array, GL_EXT_texture,
GL_EXT_texture3D, GL_IBM_rasterpos_clip, GL_ARB_point_parameters,
GL_EXT_draw_range_elements, GL_EXT_packed_pixels, GL_EXT_point_parameters,
GL_EXT_rescale_normal, GL_EXT_separate_specular_color,
GL_EXT_texture_edge_clamp, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_lod, GL_ARB_framebuffer_sRGB, GL_ARB_multitexture,
GL_EXT_framebuffer_sRGB, GL_IBM_multimode_draw_arrays,
GL_IBM_texture_mirrored_repeat, GL_3DFX_texture_compression_FXT1,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_transpose_matrix,
GL_EXT_blend_func_separate, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
GL_EXT_secondary_color, GL_EXT_texture_env_add,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
GL_INGR_blend_func_separate, GL_NV_blend_square, GL_NV_light_max_exponent,
GL_NV_texgen_reflection, GL_NV_texture_env_combine4,
GL_SUN_multi_draw_arrays, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_EXT_framebuffer_object,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_MESA_window_pos,
GL_NV_packed_depth_stencil, GL_NV_texture_rectangle, GL_NV_vertex_program,
GL_ARB_depth_texture, GL_ARB_occlusion_query, GL_ARB_shadow,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_window_pos, GL_ATI_envmap_bumpmap, GL_EXT_stencil_two_side,
GL_EXT_texture_cube_map, GL_NV_depth_clamp, GL_NV_vertex_program1_1,
GL_APPLE_packed_pixels, GL_APPLE_vertex_array_object, GL_ARB_draw_buffers,
GL_ARB_fragment_program, GL_ARB_fragment_shader, GL_ARB_shader_objects,
GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ATI_draw_buffers,
GL_ATI_texture_env_combine3, GL_ATI_texture_float, GL_EXT_shadow_funcs,
GL_EXT_stencil_wrap, GL_MESA_pack_invert, GL_MESA_ycbcr_texture,
GL_NV_primitive_restart, GL_ARB_depth_clamp,
GL_ARB_fragment_program_shadow, GL_ARB_half_float_pixel,
GL_ARB_occlusion_query2, GL_ARB_point_sprite, GL_ARB_shading_language_100,
GL_ARB_sync, GL_ARB_texture_non_power_of_two, GL_ARB_vertex_buffer_object,
GL_ATI_blend_equation_separate, GL_EXT_blend_equation_separate,
GL_OES_read_format, GL_ARB_color_buffer_float, GL_ARB_pixel_buffer_object,
GL_ARB_texture_compression_rgtc, GL_ARB_texture_float,
GL_ARB_texture_rectangle, GL_EXT_packed_float, GL_EXT_pixel_buffer_object,
GL_EXT_texture_compression_rgtc, GL_EXT_texture_rectangle,
GL_EXT_texture_sRGB, GL_EXT_texture_shared_exponent,
GL_ARB_framebuffer_object, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_packed_depth_stencil,
GL_APPLE_object_purgeable, GL_ARB_vertex_array_object,
GL_ATI_separate_stencil, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
GL_EXT_gpu_program_parameters, GL_EXT_texture_array,
GL_EXT_texture_integer, GL_EXT_texture_sRGB_decode, GL_OES_EGL_image,
GL_MESA_texture_array, GL_ARB_copy_buffer, GL_ARB_depth_buffer_float,
GL_ARB_draw_instanced, GL_ARB_half_float_vertex, GL_ARB_instanced_arrays,
GL_ARB_map_buffer_range, GL_ARB_texture_rg, GL_ARB_texture_swizzle,
GL_ARB_vertex_array_bgra, GL_EXT_separate_shader_objects,
GL_EXT_texture_swizzle, GL_EXT_vertex_array_bgra,
GL_NV_conditional_render, GL_ARB_ES2_compatibility, GL_ARB_debug_output,
GL_ARB_draw_elements_base_vertex, GL_ARB_explicit_attrib_location,
GL_ARB_fragment_coord_conventions, GL_ARB_provoking_vertex,
GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
GL_ARB_shader_texture_lod, GL_ARB_texture_rgb10_a2ui,
GL_EXT_provoking_vertex, GL_EXT_texture_snorm,
GL_MESA_texture_signed_rgba, GL_ARB_robustness,
GL_ARB_shader_bit_encoding, GL_ARB_texture_storage,
GL_ARB_invalidate_subdata
Instaluji to podle tohohle odkazu: http://www.ehow.com/how_5941905_install-call-duty- ubuntu.html
32 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x021 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x022 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x092 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x093 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x094 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x095 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x096 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x097 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x098 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x099 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x09a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x09b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x09c 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x09d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x09e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x09f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x0a0 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0a1 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0a2 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0a3 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0a4 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0a5 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0a6 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0a7 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0a8 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0a9 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0aa 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0ab 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0ac 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0ad 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0ae 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x061 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
48 GLXFBConfigs:
0x062 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x063 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x064 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x065 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x066 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x067 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x068 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x069 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x06a 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x06b 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x06c 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x06d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x06e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x06f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x070 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x071 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x072 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x073 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x074 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x075 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x076 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x077 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x078 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x079 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x07a 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x07b 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x07c 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x07d 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x07e 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x07f 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x080 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x081 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x082 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x083 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x084 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x085 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x086 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x087 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x088 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x089 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x08a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x08b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x08c 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x08d 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x08e 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x08f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x090 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x091 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
- akcelerace by měla fungovat.
Mobile Intel® GM45 Express Chipset - takže notebook? Jaký? A jste zcela přesvědčen, že ta grafika je k té hře dostatečná?
notebook mám Dell Latitude E6400, prostředí GNOME - 2,26 GHZ, dvoujádrový,
tak ti nevim karle, hra vyzaduje minimalne GF6600
takže to nepůjde?
chci to zkusit, ale nevím jak na to
