Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem Stiahnutý web template
Stiahol som si zazipovany web template
/vyzera takto/
http://img651.imageshack.us/img651/671/templateuw. png
a chcem ho vložiť na moj plateny hosting. Vlozim ho a pri prezerani webstranky mi hned vypise tuto chybu:
Fatal error: Call to undefined function is_archive() in /data/s/m/smsea.eu/web/thestyle/index.php on line 1
Na internete som nasiel, ze je to v poriadku, ale ze robim niekde chybu ja. Rozumiem po anglicky, ale absolutne nechapem, co mam robit.
Vysvetlenie:
[i]What do you do now?
You delete the files you have uploaded, except for any edited wp-config.php
You unpack the zipfile that you have downloaded from the download page -- making sure that after its unpacked you have a structure, and not a bunch of loose files. There ought to be a wp-admin folder, a wp-includes folder, and some more sub-folders.. there are 22 loose files that are in the same folder with wp-config-sample.php.
If you dont have that, you need to master using whatever program you are you using to unzip, before tackling wordpress.
You then upload the files, maintaining that same directory structure.
Once you have done all of that correctly, you wont see that error.[/i]
A ten template je na nějaký redakční systém? Nebo jsi ho jen rozbalil do rootu webu a čekáš, že to b…
Redsnake 22.01.2013 16:24
Redsnake
je to redakcny system, vlozil som ho do rootu a cakam, ze bude fungovat :( Cize ako mam postupovat?
highs 22.01.2013 16:28
highs
Jaký RS? EDIT: Tenhle web?
Redsnake 22.01.2013 16:31
Redsnake
WordPress
highs 22.01.2013 16:32
highs
Jedná se o web www.smsea.eu?
Redsnake 22.01.2013 16:33
Redsnake
Nie, to je moj iny web :) ale skusal som aj tampridat ten template + aj na free webhosting PS: Ako…
highs 22.01.2013 16:34
highs
Sám jsi to tu prozradil ;-) Fatal error: Call to undefined function is_archive() in /data/s/m/smsea…
ws79 22.01.2013 16:38
ws79
Tak s tím Ti z důvodů svého přesvědčení nepomůžu.
Redsnake 22.01.2013 16:38
Redsnake
?? Teraz nechapem prečo. Buď 1.) si myslis, ze template je nejaky warez. Ten template som kupoval…
highs 22.01.2013 16:44
highs
Protože se neztotožňuju s Tvým pojetím businessu. SMS soutěže bych přirovnal k akci "za kačku svlíka…
Redsnake 22.01.2013 16:55
Redsnake
Šikovným patrí svet a ja na tom nevidím nič zlé. SMSky chcem uz zrusit nadobro, pretoze mi odchadzaj…
highs 22.01.2013 16:59
highs
dobre, dakujem pekne za radu. Nasiel som si video, az taky hlupy nie som watch poslední
highs 22.01.2013 17:18
highs
Tu je linka na moj problem http://wordpress.org/support/topic/fatal-error-cal l-to-undefined-functio…
highs 22.01.2013 16:33
highs
1.) si myslis, ze template je nejaky warez. Ten template som kupoval vcera na stranke
thestyle
2.) alebo z toho dôvodu, že sprostredkuvam sms sutaz a tebe sa to nepaci
Ja som kupoval facebook stranky a predaval za drahsie. teraz mam okolo 700,000 ľudí (super reklama), dokonca som si na tom pekne zarobil cez 2,000 €. Rozmýšľam, že by som začal redakčný system
Protože se neztotožňuju s Tvým pojetím businessu. SMS soutěže bych přirovnal k akci "za kačku svlíkačku" a nakupování FCB stránek, resp jejich prodej s fanoušky je taky humus.
Těžko říct, jestli se mi víc hnusí podobný způsob podnikání, nebo idiocie lidí, na kterých toto podnikání parazituje.
Šikovným patrí svet a ja na tom nevidím nič zlé. SMSky chcem uz zrusit nadobro, pretoze mi odchadzaju ludia zo skupin a zisky su velmi minimalne.
Na druhej strane mi tam znova prichadzaju, pretoze mam dalsi web megazon.sk, kde mam kopu obrazkov, citatov. Článkom by som sa chcel venovať na inom webe. Tento web zaraba na adsense a ludia si ho chvalia
Som trochu prekvapený tvojou odpoveďou.
