Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem Co znamená tato zpráva?
Dostal jsem podivný mail, kterému nerozumím - je to něco důležitého, nebo je to nějaký nesmysl či spam? Kdo tomu prosím rozumíte?
IP adresu jsem zakřížkoval, jinak je to celé...
Abuse Team,
We have been made aware that the following IP addresses that you appear to host may have been used in recent cyber attacks. We have been informed these compromises may be a result of a Joomla vulnerability, and if not patched will simply be re-infected.
We request that you investigate these IP addresses to identify any malicious activity. If you are able to confirm suspicious activity, please take appropriate action to disable the malware, patch the vulnerability or remove the devices from the network.
Note: All IPs/URLs below have been confirmed as active just prior to this notification being sent. If you feel action has already been taken please reconfirm by checking the spelling/grammar of the 404 message returned (“404 Not Foun derrer” vs. “404 Not Found Error”). If you are still receiving the “404 Not Foun derrer” error message, that device may still have an issue. This can be confirmed by viewing the HTTP status with a tool like wget or cURL. If using cURL, use the following command and note the HTTP status code in the first line of output:
curl -A "Mozilla/4.0" -iL [URL]
xx.xx.xx.xx
Thank you for your immediate attention and action. Please contact us as soon as you receive this and stay in contact as we work together to resolve these issues.
Regards,
Abuse Team
Bank of America
Máš něco společnýho s Bank of America? Pokud ne, tak to klidně smaž a ještě klidněji spi.
Prasak 28.01.2013 22:33
Prasak
Kludne to zmaz. Ale nazvali sa pekne: "abuse team" :-D
CombuSteve 29.01.2013 00:10
CombuSteve
Bola to tvoja verejna IP alebo mas nejaky vlastny hosting/server? Ak nie tak to mozes ignorovat. Ak… poslední
MM.. 29.01.2013 01:48
Bola to tvoja verejna IP alebo mas nejaky vlastny hosting/server? Ak nie tak to mozes ignorovat. Ak ano tak si mas odvirit PC alebo server a prestat im utocit na ich servery :)
P.S. zabudol som evrgreen: neklikaj tam na ziadne linky a nezadavaj nikam ziadne udaje, a ani na to neodpovedaj.
