TV nechce prehrať film formátu AVI, v pc prehrať ide
Zdravím, moja TV mi nechce prehrať jeden film, piše že "momentalne nemože prehrať tento film". Nie často sa mi stáva že mi to neide a neviem kde je problém, avi,mkv,mp4 mi ide prehrať a toto je avi tak neviem kde je problém. V pc mi to v KMP player ide prehrať, ale napríklad WinMediaPlayer prehraje iba zvuk a obraz nie.
moj TV http://televizor.heureka.sk/samsung-ue40eh5450/spe cifikace/#section su tam parametre a podla všetkeho by to malo isť, neviem či je chyba v tom AVI subore alebo v TV, preto budem rád ak mi niekto poradí
Detailne info toho AVI suboru:
C:\Users\Matúš\Desktop\Interstellar-2014,-CZ.avi
General
Complete name : C:\Users\Matúš\Desktop\Interstellar-2014,-CZ.avi
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 4.04 GiB
Duration : 2h 49mn
Overall bit rate : 3 424 Kbps
Movie name : 108
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Original source form/Name : Interstellar
Video #0
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 2h 49mn
Bit rate : 3 223 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.065
Stream size : 3.81 GiB (94%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 2000
Duration : 2h 49mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 232 MiB (6%)
Alignment : Split accross interleaves
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Tak to porovnej s videem, které jde přehrát a uvidíš v čem je rozdíl. Třeba TV neumí přehrát MPEG-4 Visual zakódovaný pomocí Xvid, nebo má problém s profilem. Windows Media Player používá systémové kodeky. Když si Xvid nainstaluješ, tak to přehraje. Jiné přehrávače třeba VLC mají kodeky vlastní, takže nic instalovat netřeba.
Sice se to týká přehrávačů,ale u TV to bude podobné
http://www.digilidi.cz/avi-na-dvd-prehravacich-ane b-proc-nektere-hraje-a-jine-ne
AVI není formát videa, nýbrž kontejneru. Uvnitř toho kontejneru se nachází video- a audio-stopy, přičemž mohou být v různých formátech.
V tomto konkrétním případě je formát videa "MPEG-4 Visual" a kódováno to je XVIDem. A to může být právě problém. Sice jsou všechny MPEG-4 kodéry kompatibilní, ale TV se chytá na tzv. FourCC kód, kde máš pravděpodobně zapsáno XVID. Stačí tento kód přepsat třeba na DIVX nebo DX50 a video by mělo šlapat. K přepisu kódu můžeš použít třeba FourCC Changer.
Uz sa to tu riesilo vela krat = AVI je LEN KONCOVKA !
Kazde video v tom AVI sa deli na AUDIO a VIDEO
VIDEO ma svoj kodek v ktorom je kodovane (Divx,Xvid,mpeg4 a pod...)
AUDIO ma svoj vlastny kodek v ktorom je kodovane (AVC2, MP3 atd...)
No a tvoj problem ,, no vlastne ono to neni problem ale jednoducho tvoja TV neprehra vsetky kodedy a to je tvoja odpoved. Bohuzial stym sa musis zmierit a zmenit to nejde. Jedine si prepoj PC s TV a mas po probleme.
dakujem za rady
