WoL.. bootování s PXE
Zdravím.
Víc googlu nedam, klasicky jsem frustrovanej a bez jistoty.
Sorry, že je to tak dlouhý
Odpovídá ten text skutečnosti?
Pokud někde nesedí, kde konkrétně a proč, prosím?
Fakt si tím utřídím dost věcí. Jen jestli to sedí, překládat to nechci. Díky moc předem.
Wake On LAN (WoL) is a feature that allows a computer to be powered on. Computers that are "powered off" might actually use up a little bit of electricity, and be able to perform some very minor functions. As I recall, older computers would sometimes use a separate (set of) wire(s) that connected to the network card. These might have been made for providing some tiny amount of power or data communication. It may seem like the computer is using no electricity because it is quiet because no fans are being used, but a tiny amount of electricity can be made available for some of the cards.
If the network card was using Wake On LAN, then it would check incoming Ethernet frames for a particular pattern. If that pattern was seen, then WoL would send a message to the system (perhaps to the intelligent ATX power supply, or the motherboard's WoL pins?) to have the system "wake up" more fully. The system would then power on. Once the computer powers on, the computer will do what the computer always does whenever it powers on: the computer will boot.
To make all that happen, you need another computer on the network to send a magic Wake-on-LAN frame that will be recognized by the computer that supports WoL.
PXE is related to how the computer boots. Instead of booting from code on the hard drive, or booting code from a CD, the PXE process can be what is used for booting up the computer. This process searches a network for code to boot. If the PXE client (which is commonly built into the circuitry/chips on the computer that is booting) can locate a PXE server, then the PXE client will download code from the PXE server. After downloading code from the PXE server, the PXE client will run that code. The entire PXE process may use some other protocols, like DHCP and TFTP.
With WoL, the computer then boots up normally. "Normally" might involve PXE, or it might not. The BIOS might just boot straight to the hard drive. So, WoL and PXE don't have to be related at all. WoL just means "power on". What does the computer do when it powers on? It boots. WoL "wakes" the computer up, and that's all WoL does. Using WoL does not mean that PXE will be used.
PXE affects how the computer boots. PXE can be used when the system boots up with WoL, or when the system turns on because someone pressed the power button to turn on the computer, or possibly because software told the computer to perform a "cold"-style (full) restart. So, using PXE does not imply that WoL was used to turn the system on.
You could use WoL and then PXE, so both are used. Or just one could be used. They don't do the same thing. They are both related to the overall gigantic process of a system starting, and both involve network cards, but the similarities basically end there. They aren't really related to each other.
Regarding the other question: Yes. WoL is generally OS-agnostic, because no operating system is running, because the much of the computer is powered off. (Generally including fans, and I presume that the CPU and main system RAM might also be lacking power. That would prevent an operating system from being active.) When I've typically seen the option to use PXE, that option was built into the BIOS. I presume that add-on cards can use PXE when the BIOS checks if any add-on cards have an "option ROM" (similar to how an add-on card which is a RAID controller can allow the user to enter a RAID management tool before any operating system is loaded from a disk). PXE can download an operating system; you can even have the server provide different boot images so that the computer can download a different operating system each time it boots. The operating system that PXE boots up will be whatever code is on the image that gets downloaded.
Note that some operating systems might work better with PXE than others. They may support being able to start up with a minimal amount of data, and then use the network to locate even more data. Other operating systems may be based on a design that might expect to see all of the critical data sitting on a physical disk. So, different operating systems may support the PXE experience with different degrees of ease. Before dedicate yourself to a specific idea that relies on PXE to start up a specific operating system, take a moment to read about how easy it is to use that operating system with PXE. Enough people have enjoyed dabbling with PXE that such information is probably relatively easy to find.
Je to vicemene spravne, jen nektere formulace nejsou presne. WoL neovlada zdroj, ale posle signal chipsetu, a ten potom nasledne zapne system.
Tohle číst nebudu. Sorry.
Zbytečně moc keců kolem.
WoL je funkce řadiče síťovky, který zůstává napájen z 5V standby větve zdroje (tj. síťovka "svítí" i když je PC kompletně "vypnutý" - u ATX je to stav, kdy funguje pouze 5V standby.
PXE je (relativně nový) protokol používaný pro boot systému přes síť (tedy OS se zavádí ze sítě). K tomu je třeba odpovídající síťová karta s vlastním BIOSem a/nebo podpora BIOSu. Dříve se používal "čistý" BOOTP/DHCP/TFTP.
Kombinace WoL a PXE umožňuje PC vzdáleně probudit a zavést OS ze sítě (tj. bez interního HDD), oba protokoly ovšem spolu přímo nesouvisí.
Mas aj nejaky realny problem?
Alebo len "překládat to nechci" a poterebujes vysvetlit text, ktory si systemom Ctrl+S/ Ctrl+V dodal?
Co tak pozret sa na stranku dotazu:
add
Naozaj neviem, ako dotaz vyhodnotit.
ked mas domaci pocitac, tak "bootování s PXE" Ta urcite nazaujuma.
ked je to firemny PC, tak bezny uzivatel to stejne musi riesit so spravcom siete.
WoL je funkcia, ktora sa da realizovat na zaklade urcitych predpokladov.
PC nesmie byt vypnute (sleep mode), verejna IP-adresa, staticka IP-adresa...
Dodam ze wol moze fungovat aj z S5 (po start-vypnut vo Win), ale treba to bud nastavit v biose alebo ovladaci (spravca zariadeni - lan - vlastnosti - magic packet v S5), aby niekto z nich povolil wake event pri prechode do S5, ptz standardne to win robil len pri S3-4 (sleep a hibernate)
Můžu si vybrat z s0 nebo s3-s4-s5, nemůžu se teď podívat a asi krcam jen vím že jsou tam dvě možnosti a jedna z nich je s0
To si ale pozeras nieco uplne blbo.
Repasovaný e6320/ intel s vPro technologii/ professional windows 10/ intel mebx/ boot s pxe/ wol/ control radio wlan-wlan /control radio wwan/ MEBx/ atd...
zatím nedostatek znalostí vidět siť jako kompletní obraz, tuny informací málo času/ potřeba vědět/
málo zkušeností.
/prostě si ten obraz skládám neúmyslně nesystematicky a až si ho poskládam tak to poznam.
Pak se mi bude chápat stručná odpověď snadno.
No nabývám dojmu, že vůbec nesmuim tušit že co se mi tam děje
Jufo: Buď to trolíš a tvůj styl mě vážně pobavil
Nebo jseš debil.
Taky nevím jak tvoji odpověď vyhodnotit.
I tak sem se smál, akorát spíš ne díky tobě
Tymto si sa pekne strapnil.
Uvedom si ze si v poradni, kde sa radi zadarmo a kazdy kto Ti odpise, to robi na ukor svojho casu.
Samozrejme, ze kazda odpoved Ti nemusi vyhovovat, tak ju ignoruj.
(mimochodom moja odpoved bola slusna a k veci)
Ale urazat a nadavat do debilov, je vrchol neslusnosti.
Asi dost slusneho vychovania sa Ti nedostalo.
Samozrejme si to precitaju aj dalsi poradcovia a vyhodnotia ako Ti budu v buducnosti pomahat.
Přečti si můj dotaz(klidně bez té ang. části)! Pak si přečti tvojí reakci, pak si to uvědom:)
Navíc já jsem se v tu chvíli fakt zasmál. Je to vtipný trolení, pokud bys to tak ovšem myslel...
Chápej... na můj dotaz (chronologicky!)
JSI tvojí chybou vyhodnocoval mojí příčetnost,
pak sis maličko nahonil ego, dostal jsi nesmyslnou potřebu poučit+umravnit mě,
no a nakonec mě odkážeš na odpověď někoho jiného,
a pak mě odkázal na odpověď někoho cizího a to s určitostí více-méně?.:D
no nezlob se na mě, ale prostě je to buď vtipnej trolling:D
Když řeknu: "jsi debil", ve skutečnosti tim myslim: "seš jednoduchej"
Tak nějak jsem si říkal, že ten debil tě nebude provokovat. Pokud bereš debil opravdu doslova, Pak se omlouvám tak jsem to nemyslel(
A poslední poznámka. Všimni si co jsem ti prve řekl, že neumim vyhodnotit jestli jsi fakt vtipnej NEBO debil(jednoduchej).. Dvě logický možnosti. Já předem nesoudim, čekal jsem až dodáš data. No... za to si už můžeš sám:(
Pokud nesplníš první řádek, nikdy si to ho nešimneš. Tak se pouč a nebuď:)
tazatel nepřiložil ruku k dílu, nenapsal co chce vlastně rozchodit a co nejde, jen sem dokola píše užvaněné fejetony, vyžívá se ve slově debil a poučuju tě, jak mu máš odpovídat.
fak materiál.
Ale já jsem přece napsal otázku docela jasně. Pokud to tak neni pak se omlouvám ale nevidím opak.(chápu že celkově je dotaz dlouhý, ale já to právě z toho odkazovaného anglického textu snadno pochopil, jen jsem si nebyl jistý jestli byl autor přesný)
Já se ptal jestli text souhlasí se skutečností. A že překlad nepotřebuji.
A že si tím ujaním dost věci(já to beru jako důvod protože to tak opravdu bylo)
za odpovědi vám děkuji a vážim si jich!
Ten dlouhej koment byl jen k jedné odpovědi k jednomu konkrétnímu odpovídajicímu/neodpovídajícimu
" Jufo"(jen jsem to nezdůraznil) původně mě ten kontrast mezi otázkou a jeho odpovědí fakt pobavil.
Z mojho pohladu si sa naozaj pytal dost nestastne, preto som ani na povodny dotaz neodpovedal.
Mas sa pytat konkretne, nie sem pastnut A4 textu a cakat, ze niekto to bude luskat riadok po riadku.
Povodne som sa aj domnieval ako zvysok, ze ti ide o kontrolu prekladu a to sa mi robit nechcelo;o).
Mas sa pytat na to ze co ti neni jasne, nevidime ti do mozgu ze ci to chapes spravne.
WOL je zapnutie cez LAN, funguje tak ze router posle magic packet na MAC (!) adresu daneho PC, a to PC musi mat aktivny wake event na magic packet (to sa udeje az potom ako bezal OS alebo niekto kto to aktivuje pri prechode do prislusneho S-stavu (sleep = S3, hibernacia = S4, soft off = S5). T.j. zvycajne to neni aktivne hned po zapnuti zdroja (!) a teda po vypadku elektriky si v takych pripadoch treba nastavit poweron po AC power loss a po nabehnuti OS PC uspat.
PXE je bootovanie z LAN, nema ziaden suvis s WOL, bootovat z LAN mozes aj po normalnom zapnuti, a naopak po WOL mozes aj normalne bootovat z HDD.
Musis povolit v BIOSe PXE a dat ho navrch do boot order, a musis mat v LAN sieti nejaky PXE server, a potom to nabootuje z LAN z toho PXE servera.
