Jak jsi ten router zapojil a nastavil?
Presne podle navodu na strankach tplinkwifi.net router vali na 2 ntb a 2 telefonech jen muj ntb nechce zadnou sit
v příkazovém řádku (cmd.exe) zadejte:
vypíše vám nastavení síťových adapterů, text sem zkopírujte.
2
Microsoft Windows [Version 10.0.15063]
(c) 2017 Microsoft Corporation. Všechna práva vyhrazena.
C:\Users\User>(cmd.exe)
C:\Users\User>ipconfig - all
Error: unrecognized or incomplete command line.
USAGE:
ipconfig [/allcompartments] [/? | /all |
/renew [adapter] | /release [adapter] |
/renew6 [adapter] | /release6 [adapter] |
/flushdns | /displaydns | /registerdns |
/showclassid adapter |
/setclassid adapter [classid] |
/showclassid6 adapter |
/setclassid6 adapter [classid] ]
where
adapter Connection name
(wildcard characters * and ? allowed, see examples)
Options:
/? Display this help message
/all Display full configuration information.
/release Release the IPv4 address for the specified adapter.
/release6 Release the IPv6 address for the specified adapter.
/renew Renew the IPv4 address for the specified adapter.
/renew6 Renew the IPv6 address for the specified adapter.
/flushdns Purges the DNS Resolver cache.
/registerdns Refreshes all DHCP leases and re-registers DNS names
/displaydns Display the contents of the DNS Resolver Cache.
/showclassid Displays all the dhcp class IDs allowed for adapter.
/setclassid Modifies the dhcp class id.
/showclassid6 Displays all the IPv6 DHCP class IDs allowed for adapter.
/setclassid6 Modifies the IPv6 DHCP class id.
The default is to display only the IP address, subnet mask and
default gateway for each adapter bound to TCP/IP.
For Release and Renew, if no adapter name is specified, then the IP address
leases for all adapters bound to TCP/IP will be released or renewed.
For Setclassid and Setclassid6, if no ClassId is specified, then the ClassId is removed.
Examples:
> ipconfig ... Show information
> ipconfig /all ... Show detailed information
> ipconfig /renew ... renew all adapters
> ipconfig /renew EL* ... renew any connection that has its
name starting with EL
> ipconfig /release *Con* ... release all matching connections,
eg. "Wired Ethernet Connection 1" or
"Wired Ethernet Connection 2"
> ipconfig /allcompartments ... Show information about all
compartments
> ipconfig /allcompartments /all ... Show detailed information about all
compartments
C:\Users\User>c
Kurt tam ziadnu medzeru medzi - a all nemal.
Ty Pavle neumíš ani trošku anglicky?
Píše ti to:
Chyba: nerozpoznaná nebo neúplná příkazová řádka.
Takže zkus podle nápovědy
ipconfig /all
nebo ipconfig -all
ale nikde si nepřidávej žádné mezery!
ano anglicky neumím, umím německy a jelikož jedu přes mobil tak není poznat zda tam mezera je nebo není :( omlouvám se
C:\Users\User>ipconfig -all
Windows IP Configuration
Host Name . . . . . . . . . . . . : LAPTOP-V6C4O0TK
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : F0-76-1C-FF-5F-23
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Připojení k místní síti* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : B4-6D-83-E6-3D-B4
Wireless LAN adapter Připojení k místní síti* 5:
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Physical Address. . . . . . . . . : B6-6D-83-E6-3D-B3
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 3160
Physical Address. . . . . . . . . : B4-6D-83-E6-3D-B3
Link-local IPv6 Address . . . . . : fe80::e9e6:fb9:d475:63e6%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.100(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : čtvrtek 8. června 2017 16:49:47
Lease Expires . . . . . . . . . . : čtvrtek 8. června 2017 18:49:46
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 78933379
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1E-97-16-12-F0-76-1C-FF-5F-23
DNS Servers . . . . . . . . . . . : 192.168.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Síťové připojení Bluetooth:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : B4-6D-83-E6-3D-B7
Tunnel adapter Připojení k místní síti* 14:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
C:\Users\User>
Zkus přejít do cetra síťových připojení, rozklikni si název své sítě > vlastnosti > protokol IPv4 > DNS a nastav 8.8.8.8 a 8.8.4.4. Funguje?
nemáš doufám takzvaný antivir avast?
