JavaFX - Proč není text zarovnán na střed?
Mám problém se zarovnáním. Když napíšu např.
import javafx.geometry.VPos;
import javafx.scene.Scene;
import javafx.scene.layout.GridPane;
import javafx.scene.layout.Pane;
import javafx.scene.paint.Color;
import javafx.scene.text.Text;
import javafx.scene.text.TextBoundsType;
import javafx.stage.Stage;
public class TextAlignment extends javafx.application.Application {
@Override
public void start(Stage stage) {
var gridPane = new GridPane();
gridPane.setStyle("-fx-background-color: yellow ;");
gridPane.setHgap(10);
gridPane.setVgap(10);
var texx = "EXAMPLE";
for (var i = 0; i < texx.length(); i += 1) {
var text = new Text(String.valueOf(texx.charAt(i)));
text.setBoundsType(TextBoundsType.VISUAL);
text.setTextOrigin(VPos.BOTTOM);
text.setTextAlignment(javafx.scene.text.TextAlignment.CENTER);
text.setFill(Color.BLUE);
var textPane = new TextPane(text);
textPane.setLayoutX(0);
textPane.setMinHeight(100);
textPane.setMaxHeight(100);
gridPane.add(textPane, i, i);
stage.setScene(new Scene(new Pane(gridPane), 600, 800));
stage.show();
public static void main(String[] args) {
launch(args);
Objekt textPane je vytvořen pomocí třídy níže
import javafx.geometry.Orientation;
import javafx.scene.text.Font;
public class TextPane extends javafx.scene.layout.Region {
private final Text text;
public TextPane(Text text) {
this.text = text;
getChildren().add(text);
@Override
protected void layoutChildren() {
adjustFontSize(getHeight());
text.setY(getHeight());
text.setX(0);
private void adjustFontSize(double height) {
var textHeight = text.getBoundsInLocal().getHeight();
if (Math.abs(height - textHeight) > 1) {
var currentFont = text.getFont();
var fontSize = currentFont.getSize();
text.setFont(Font.font(currentFont.getFamily(), height * fontSize / textHeight));
System.out.println(text.getLayoutBounds().getWidth());
@Override
protected double computePrefWidth(double height) {
adjustFontSize(height);
return text.getBoundsInLocal().getWidth();
@Override
public Orientation getContentBias() {
return Orientation.VERTICAL;
Tak se zobrazí
Proč je, prosím Vás, text špatně zarovnaný a jak to opravím?
Děkuji
Není zarovnaný, protože to vkládáš do "tabulky", kde se šířka sloupců přizpůsobuje obsahu. Takže každé písmeno je vždy až za předchozím.
Pokud by sloupce měly pevnou šířku, mohlo by to pomoct.
GridPane jsou pouze použil jako příklad. Když kód změním třeba na HBox, tak je výsledek stejný.
Nebo když to pouze vložím do Pane
Problémem je to, že je text vždy záhadně zleva odsazený bez ohledu na použitý layout. A vážně netuším, jak to opravit. Nevíte to, prosím?
