Tinymce spellchecker problem
Zdravim, mam problem se spellchecker v tinyMce.
- aplikoval jsem plugin
- do stranky s editorem jsem aplikoval
spellchecker_languages : "+Čeština=cs,English=en",
spellchecker
entity_encoding : "raw",
- po kliknuti na preklad
Error response: <br />
<b>Warning</b>: fsockopen() [<a href='function.fsockopen'>function.fsockopen</a>]: unable to connect to ssl://www.google.com:443 (Unable to find the socket transport "ssl" - did you forget to enable it when you configured PHP?) in <b>C:\Weby\eshop\editor\jscripts\tiny_mce\plugins\ spellchecker\classes\GoogleSpell.php</b> on line <b>85</b><br /> Could not open SSL connection to google.{"id":null,"result":[],"error":null}
Dale nevim jak to funguje, vyuziva to na pomoc google? .....
Naco zakladat duplicitnu temu.
