PHP - platnosť $_SESSION
Vie mi niekto poradiť ako zistím, že ako dlho platí pole $_SESSION?
| V konfiguračním souboru: php.ini
Někde tady:
; Define the probability that the 'garbage collection… Flash_Gordon 28.05.2009 15:28 |
Flash_Gordon | |
| RTFM! :-)
http://www.php.net/manual/en/function.session-cach e-expire.php
nebo taky s pomocí sessio… marekdrtic 28.05.2009 15:29 |
marekdrtic | |
| Platnost session sa myslim ze da aj menit:
ini_set('session.gc_maxlifetime', 3600); // 1 hodina
a… poslední Intex 28.05.2009 17:44 |
Intex |
Někde tady:
; Define the probability that the 'garbage collection' process is started
; on every session initialization.
; The probability is calculated by using gc_probability/gc_divisor,
; e.g. 1/100 means there is a 1% chance that the GC process starts
; on each request.
; This is disabled in the Debian packages, due to the strict permissions
; on /var/lib/php4. Instead of setting this here, see the cronjob at
; /etc/cron.d/php4, which uses the session.gc_maxlifetime setting below
;session.gc_probability = 0
session.gc_divisor = 100
; After this number of seconds, stored data will be seen as 'garbage' and
; cleaned up by the garbage collection process.
session.gc_maxlifetime = 1440
RTFM!
nebo taky s pomocí session.gc_maxlifetime
PS: pozdě
a ziskat cez:
ehm: neda sa ziskat aj cez funkciu:
a nastavit tiez cez to:
To som si len vygooglil... neskusal som...
