Smart disku
Dobry den, moc se ve smart testu nevyznam, je toto u tyden stareho ntb normalni??? Hlavne se mi jedna o polozky 005,191,196. Diky.
HDDScan S.M.A.R.T. Report
Model: TOSHIBA MK5055GSX
Firmware: FG002C
Serial: 89FDS1PCS
LBA: 976773168
Report By: HDDScan for Windows version 3.1
Report Date: 30.10.2009 19:17:42
Num Attribute Name Value Worst Raw(hex) Threshold
001 Raw Read Error Rate 100 100 00000000-0000 050
002 Throughput performance 100 100 00000000-0000 050
003 Spin Up Time 100 100 00000000-066C 002
004 Start/Stop Count 100 100 00000000-0044 000
005 Reallocation Sector Count 071 071 00000000-025E 010
007 Seek Error Rate 100 100 00000000-0000 050
008 Seek time Perfomance 100 100 00000000-0000 050
009 PowerOn Hours Count 100 100 00000000-0031 000
010 Spin Retry Count 101 100 00000000-0000 030
012 Device Power Cycle Count 100 100 00000000-0042 000
183 Unknown Attribute 100 100 00000000-0001 001
184 End to End Error 100 100 00000000-0000 097
185 Unknown Attribute 100 100 00000000-FFFF 001
187 Reported Uncorrectable Error 100 100 00000000-0000 000
188 Command Timeout 100 096 00000000-0019 000
189 High Fly Writes 100 100 00000000-0000 001
190 Airflow Temperature 063 056 37 C 045
191 G-sense error rate 100 100 00000000-0002 000
192 Power-off retract count 100 100 0000000A-000A 000
193 Load/unload cycle count 100 100 00000000-04D1 000
196 Reallocation Event Count 100 100 00000000-0057 000
197 Current Pending Sector Count 100 100 00000000-0000 000
199 UltraDMA CRC Error Count 200 200 00000000-0000 000
Tak v tomhle se nevyznám - instalni Speed fan / záložka S.M.A.R.T.
Tam klikni na to velký tlačítko: perform an in-dept... Otevře se to internetová stránka, a dole u textu "The link to get back and see a new report about this hard disk in the future is this. Consider that new hard disks and new checks are added over time. " je odkaz, který sem vlož. Mrkneme.
tak tady to je:
http://www.hddstatus.com/hdrepshowreport.php?Repor tCode=4095484&ReportVerification=B017D105
škoda, nejde mi to načíst - patrně určeno jen pro tebe.
Attribute Current Raw Overall
Raw Read Error Rate 100 0 Very good
Throughput Performance 100 0 Very good
Spin Up Time 100 1659 Very good
Start/Stop Count 100 69 Very good
Reallocated Sector Count 71 606 Good
Seek Error Rate 100 0 Very good
Seek Time Performance 100 0 Very good
Power On Hours Count 100 49 Very good
Spin Retry Count 101 0 Watch
Warning: Spin Retry Count is below the average limits (104-253).
Power Cycle Count 100 67 Very good
Unknown attribute 183 100 1 Very good
End To End Error Count 100 0 Very good
Unknown attribute 185 100 65535 Very good
Reported Uncorrectable Errors 100 0 Very good
Command Time Out 100 25 Very good
High Fly Writes 100 0 Very good
Airflow Temperature 66 606208034 Normal
GSense Error Rate 100 2 Very good
Power Off Retract Count 100 655370 Very good
Load Cycle Count 100 1234 Very good
Reallocated Event Count 100 87 Very good
Current Pending Sector 100 0 Very good
Ultra DMA CRC Error Rate 200 0 Very good
To nevypadá moc dobře. Zálohuj preventivně data a sleduj, jestli se to bude zhoršovat.
JJ
Spin Retry Count - Počet opakovaných pokusů o roztočení ploten. Pokud není rovno nule, zálohujte.
http://www.svethardware.cz/art_doc-550EF2B6631B2E2 1C1256F60006766C8.html
Nato, že to je novej disk ... šel bych ho reklamovat.
Stáhni si HDD Health, tam je to celkem přehledné, ukáže to přímo kondici disku v procentech.
ukazuje kondici 71%, to po tydnu prace neni dle me moc dobre
No, to u nového disku opravdu není nic moc.
reklamace?
Zálohuj data a průběžně sleduj stav. Jakmile se to ještě zhorší, hned na reklamaci.
P.S.: Hloupé je, že zrovna Toshiba myslím nemá žádnou testovací utilitu ke svým diskům. Kdyby to byla jiná značka, bylo by to jednodušší.
DFT od Hitachi by měl/mohl zvládnout otestovat i Toshibu.
http://www.hitachigst.com/hdd/support/download.htm #DFT
Díky za tip.
