Skonvertovanie filmu
zdravim, mam tu jeden film s nasledujucimi informaciami
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 2.13 GiB
Duration : 1h 34mn
Overall bit rate : 3 231 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Video
Format : MPEG-4 Visual
Format profile : AdvancedSimple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Custom
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 34mn
Bit rate : 2 579 Kbps
Width : 1 280 pixels
Height : 544 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.154
Stream size : 1.70 GiB (80%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 1h 34mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 432 MiB (20%)
Alignment : Split accross interleaves
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 500 ms
a potreboval by som ho skonvertovat na format ktory zvladne DVD prehravac (zvlada AVI, ale asi nie vsetky formaty)
naunstaloval som si Avidemux, ale nemam sajnu ako sa s nim pracuje, tak by som poprosil o kratky navod, nakolko na google som sa nedostal k ziadnemu
diky vopred aj za zdrbanie :)
doplnenie - otvorim si to video v avidemux, nastavim video na MPEG-4 (lavc), audio na MP3, format na AVI, ale neviem co dalej.
Žeby: Ctrl-S Save video... ???
kam to defaultne uklada tie ulozene videa?
ok, uz to mam, sorry, predtym som na to klikal v blbom poradi
