Po novej inst XP nejde siet
Vymenil som hdd v notebooku, nakolko stary siel do prec. System sa podarilo nainstalovat, vratane stiahnutych ovladacov zo stranky vyrocu, az na jeden vykricnik - nejaky LPC interface . . . ? Myslel som ze dam vyhladavat na nete, ale . . . ale neda sa mi pripojit na siet. Nedostanem IPcku. Ovladace sietovej karty su nainstalovane, nehlasi ziaden problem, wifina dtto. Aj ovladace, a aj tak nedostane IPcku. Router je OK, druhy notebook aj cez wifi aj cez kabel. Aj ked to bude mozno vystrel do tmy, aj tak sa spytam, kde moze byt problem? prideli mi len IPcku rezervovanu co prideluje Win ... (169 ...alebo tak nejako)
je to tady furt v kuse - samoadmini nenávidí driver chipsetu a zásadně ho neinstalují, po přeinstalaci win jim vždycky chcípne síť.
ten som instaloval ako prvy hned po instalacii xpcok.
http://www-307.ibm.com/pc/support/site.wss/documen t.do?lndocid=MIGR-67856
Instaloval si tam toto ?
__________________________________________________ __________________________
his package contains the following support modules.
- To detect and configure the INTEL GM965 Express Chipset and INTEL PM965 Express Chipset
The following systems are supported:
- ThinkPad R61, R61e, R61i
- ThinkPad T61, T61p
- ThinkPad X61, X61s, X61 Tablet, X300
- ThinkPad Reserve Edition
Notes:
- If you use the Product Recovery function shipped with your ThinkPad to restore the Windows preload environment, you do not need this package. This package is required when you install Windows operating systems without the Product Recovery function.
- This program is based on the US version but, this is language independent and can be used with any language system.
File details
Version: 8.2.0.1012
Release Date: 2007/12/31
File link File size File description
oss704ww.exe 2,437,072 Intel chipset support
oss704ww.txt 7,030 README for Intel chipset support
toto, je to z toho odkazu vyssie
Intel Chipset (Intel GM965, Intel PM965 Express Chipset)
Windows Vista, XP, 2000
31 Dec 2007
8.2.0.1012
potom bys měl vidět ve správci zařízení co ti přesně chybí, pokud to nemá ovladač.
síťovka je nainstalovaná?
ještě jedna věc: lidi občas trpí mánií instalovat antivirové balíky s co nejvíc "funkcemi", a pak se diví že jim nejde síť. jak jsi na tom?
z tohto phladu dobre, instaloval som len XP + sata, chipset, grafika, zvukovka, nejaky support key klavesnice a pod, len to co je na tej stranke lenovo k R61 k prislusnemu modelu a OS . . . okrem tych poslednych patchov - tie su uvedene ze only US OS . . . co s atyka antivir, vypol som aj aktualizacie automaticke a docasne aj vstavany firewal . . .
apropo, neviem, ale aj cez mnozstvo funkcii roznych antivir, by IPcku mohol mat pridelenu . . .
Toto sa tu riesi kazdy den.
- pripajas sa kablom? Ak ano iny pc na tom kabli ide?
- pripajas sa wifi? Ak ano ide wifi funguju? Puzivas kryptovanie? Log na routri ukazuje nejake chyby?
- mas instalovany spravny ovladac na sietovku?
- skusal si zadat pevnu ip a pokusit sa opingovat router>?
- skusal si nejaku live distribuciu linuxu?
-kabel ano, na dell funguje, lenovo nedostane IP
-wifi ano, dell OK, lenovo nedostane ip
-ovladac je dufam OK, aj jeden aj wifi, ziadne otazniky, win pise ze zariadenie funguje , ovl. stiahnute zo stranky notebooku, vid vyssie
-pevnu som neskusal, bolo uz skoro rano
-live linux zatial nevlastnim
