PROSIM O POMOC
AHOJ PROSIM POMOZTE MI MAM TAKOVY PROBLEM S MYM PC PORAD SE MY RESTARTUJE BEHEM DNE I NEKOLIKRAT DENE A KDYZ VLOZIM CD TREBA S FILMY TAK SE MI TAKE RESTARTUJE,I KDYZ DAM FLESKU DO USB PORTU TAK TAKE Z PRVA JSEM MYSLEL ZE TO MUZE DELAT ZDROJ TAK JSEM KOUPIL SINEJSI 450W A PORAD NIC TAK JSEM VYSKOUSEL I GRAFARNU A I RAMKY ALE PORAD.NEVIM CO STIM A UZ JSEM S TOHO ZOUFALEJ A JENOM DO TOHO STRKAM PRACHY.PROSIM POMOZTE
Nejdřív si vypni CapsLock, pak si 2x přečti tento text a vlož dotaz znovu. (host)
