Přidat aktualitu mezi oblíbenéZasílat nové komentáře e-mailem Total Commander 7.55 beta 1
What's new?
* Use MLSD command for file listings in FTP function (better time resolution, time in UTC)
* Transfer files between two computers over a special USB cable
* Improvements to synchronize dirs function: Compare via plugins and FTP, options to skip hidden files and hard links, SITE UTIME in ftp sync
* Compare by content now shows different and changed lines with a slightly different background color (configurable via wincmd.ini)
* FTP connection details dialog split into two tabs
* "cd" command in button bar and start menu now accepts parameter /user: (user name for network connection)
* Open archives also in virtual folders like the Desktop
* New internal commands with parameters SELECTFILES, OPENTABSL and OPENTABSR, e.g. for the button bar
* Let the user set the user agent for HTTP connections
* Unpack directory time stamps from archives
* Lister: Increased maximum line length to 1024 characters (Unicode: 512)
* Verify CRC checksums: Also support CRC files in UTF16 Unicode format
* Show Terminal Server and Win7 XP mode drives in drive dropdown list and drive buttonbar
* Ctrl+Shift+B and cm_DirBranchSel shows branch view of only the selected dirs+files
* Colors by file type: Get plugin data in background thread for slow plugins
* F5 copy dialog: "Options" dialog extension can be pinned now to remain open
* RAR with encrypted file names: Show pseudo file <Encrypted -> F5> and let user unpack the archive with F5
* Command line: Command "cd filename" places cursor directly on file with name "filename"
* Search in "feed to listbox" results: Respect option "Search subdirectories", e.g. to search 3 levels deep in all selected dirs
* Show progress dialog box when reading a directory takes longer than 5 seconds
* Create CRC checksums: support subdirectories (recursively), background button
* Multi-rename tool: Allow to create fields with leading zeroes or spaces
* Create shortcuts (LNK files) also in protected system directories
* Handle dir space calculation in background (when user presses SPACE or Alt+Shift+Enter)
* Internal UnRAR via unrar.dll: Support target names longer than 259 characters
* File system plugins: Support background downloads and uploads (requires changes to plugin)
* Various new background operations: Unpack: RAR, TAR, packer plugins (needs modification), Pack: TAR, packer plugins
* See history.txt for all additions and fixes
755_b1.php
Zdroj: Ghisler.com
doporučuju všem vyzkoušet si Total Commander Ultima Prime je to fakt parádní modifikace
Nigfire 26.03.2010 22:04
Nigfire
Nechci byt impertinentni, ale co je na nem tak uzasneho? Co cekas od komanderu, nez diskove/sitove o…
mif 26.03.2010 22:26
Nejvíc se mi líbí, že si při instalaci zvolíš doplňky, které potom bude TC automaticky používat např… nový
Nigfire 27.03.2010 21:52
Nigfire
TC pouziva snad vacsina preto lebo v tom nie su hnusne omalovane blbosti ktore by len odputavali poz… nový
MM.. 27.03.2010 02:09
Aj preto nie som schopny pracovat s PC ked tam je XP vzhlad (nevidim obsah okna, len oramovanie :)… nový
L-Core 27.03.2010 06:28
L-Core
Nejspis nas bude vic. Neco jineho, nez W2K vzhled nesnesu. Pral bych ti ale slyset zakazniky, kterym… nový
mif 27.03.2010 10:39
W2K vzhled nesnáším, XP default taky nic moc, Royale Theme je pěkné... nový
vlk56 27.03.2010 10:46
vlk56
Nikdo ti to nebere. Mne (a mnohym podobne postizenym) ale slouzi PC k praci, tudiz preferuji technic… nový
mif 27.03.2010 10:50
Ok, jsem zastánce názoru: "Když už to mám používat, ať to nějak vypadá...". Každému co jeho jest. nový
vlk56 27.03.2010 10:58
vlk56
V testu Chipu vyhrál FreeCommander. ;-) nový
Tomix nologin 27.03.2010 22:34
Tomix nologin
No nevim... Jednak je to zdechle jak slimak po obrne, druhak ta preplacana lista... nový
mif 28.03.2010 10:14
lebo TC je uplne rychly :-) hlavne pri praci so sietovymi zlozkami nový
wam_Spider007 28.03.2010 12:34
wam_Spider007
Co ten sarkasmus :-)? Ano, TC je rychly jak blesk (aspon ta "moje" sestkova verze). I v praci se sit… nový
mif 28.03.2010 16:58
ja som na par dni TC skusil v praci realne pouzivat (doteraz som pouzival len "compare by content" a… nový
wam_Spider007 28.03.2010 18:27
wam_Spider007
To co popisujes jsem nezaznamenal. Pravda ovsem je, ze tezce "rozdychava" vadnou placku (CD/DVD s ch… nový
mif 30.03.2010 19:06
Ono zas ale Free Commander má pre mňa okrem istých nedostatkov v porovnaní s TC jednu nezanedbateľnú… nový
deadhead 28.03.2010 18:28
deadhead
mif je můj člověk. Odstranil jsem po jisté události totálně TC z počítače, nepotřebuji to ani doufám… nový
georgeII 28.03.2010 20:17
georgeII
Používám Průzkumníka se stromem a TC pouze v mobilu - tam je super. nový
Kráťa 28.03.2010 23:49
Kráťa
Ja mám TC zakúpený a bez neho si neviem predstaviť život. Kto robí na štýl "multitasking" tak určite… nový
Len tak 29.03.2010 16:21
Len tak
salamander na hrad :-p (tc že je rychlý při práci v síti? snad na menší jednoduché síti, kde nikdy… poslední
lední brtník 04.04.2010 14:32
Nejvíc se mi líbí, že si při instalaci zvolíš doplňky, které potom bude TC automaticky používat např když zmáčkneš F4 tak se ti soubor otevře v Notepad++ místo obyčejnýho pozn. bloku. Další super věc je ten integrovanej archivátor (tuším 7z) díky němuž si už na winRAR ani nevzpomeneš (umí otvřít i ISO takže nepotřebuješ daemon tools). Vzhled si samozřejmě můžeš nastavit, já používám ten klasickej. Další věc ale to si nejsem jistej jestli to není dokonce i u obyč TC je, že ho můžeš nastavit jako výchozího průzkumníka ve winu.
Takže ne kluci kvůli omalovánkám to není
TC pouziva snad vacsina preto lebo v tom nie su hnusne omalovane blbosti ktore by len odputavali pozornost resp. tak bili do oci ze by sa ani nedali precitat potrebne veci. Aj preto nie som schopny pracovat s PC ked tam je XP vzhlad (nevidim obsah okna, len oramovanie :). Keby som chcel omalovanky tak pouzivam explorer a mebudem platit 30euro ci kolko za TC.
ja som na par dni TC skusil v praci realne pouzivat (doteraz som pouzival len "compare by content" a nejake dalsie blbinky) a ziadna slava. Pokial ma zlozka viac suborov, tak to tazko rozdychava, hlavne ked odminimalizujem okno. Proste v jednom kuse ten TC nieco vykonava a neviem naco. Dalsia vec, ked som napriklad pripojeny vo VPN a prezeram si zlozky nejakeho PC, ktory v tej VPN je, tak celkom OK, ale nebodaj spadne VPN spojenie a s TC je amen.
Takze TC pre mna ostane uz asi navzdy iba ako nastroj pre "compare by content" ci rychle prezeranie logov, ktore su vo formate TXT.
Mozno su moje problemy sposobene tym, ze to pouzivam na Win7 - neviem, ale zistovat to nejdem. Mozno by este nebolo odveci skusit SpeedCommander. Do tej doby ale vo windowse u mna vyhrava klasicky (s)explorer. Uvital by som v nom ale aspon podporu tabov :-(.
