excel 2010 VBA: ako zmenit farbu klikacieho listu a default highlightu vo VBA ?
ked mam tmavu temu windows 7, modra farba listu co mi spravil siki je zle citatelna a tiez modry highlight keywords vo VBA samotnom. tieto 2 veci by som potreboval zmenit na bud svetlu modru, svetlu zelenu alebo zltu farbu
toto je ten kod. ja som skusal dat na 2 miesta riadok:
.Characters.Font.Color = vbRed
ci sa nieco zmeni ale nic. fungovalo to normalne a bez zmeny
Sub Sheet_lister()
Dim ceLL As Range
Dim i As Long
Dim Button1 As Object
Dim Button2 As Object
Dim Ws1 As Worksheet
Dim Ws2 As Worksheet
Dim Exist As Boolean
Application.ScreenUpdating = False
For Each Ws1 In Worksheets
If Ws1.Name Like "Sheet List" Then Exist = True: Exit For
Next
If Exist = True Then
With Sheets("Sheet List")
.Activate
.Columns(1).Clear
End With
Else
Sheets.Add before:=Worksheets(1)
ActiveSheet.Name = "Sheet List"
With Range("A1")
Set Button2 = ActiveSheet.Buttons.Add(Left:=.Left, Top:=.Top, Width:=.Width, Height:=.Height)
End With
With Button2
.Name = "Button2"
.OnAction = "Sheet_lister"
.Characters.Text = "Make list"
.Characters.Font.Name = "Arial"
.Characters.Font.Size = 11
'.Characters.Font.Bold = True
End With
End If
For i = 2 To Sheets.Count
Cells(i + 1, 1) = Sheets(i).Name
Columns(1).AutoFit
If Columns(1).ColumnWidth < 18 Then
Columns(1).ColumnWidth = 18
End If
Cells(i + 1, 1).NumberFormat = "@* "
Next i
For Each ceLL In Range("A3", Range("A3").End(xlDown))
ceLL.Hyperlinks.Add Anchor:=ceLL, Address:="", _
SubAddress:="'" & Replace(ceLL.Value, "'", "''") & "'" & "!a1", ScreenTip:="Click to move to sheet", TextToDisplay:=ceLL.Value
Next
Range("A3:A" & Cells(Rows.Count, "A").End(xlUp).Row).Font.Underline = xlUnderlineStyleNone
Application.ScreenUpdating = True
Sheets("Sheet List").Activate
End Sub
Sub Back()
End Sub
teraz to mam otvorene v excel 2016 a aj tam je to rovnake modre (obe veci) pri defaultnej teme win7.
halo
dik
kde ste seci excelaci ?
a robertko ? odkedy dostal radcovsku nalepku, moc sa uz neukazuje ...
Odstráň .Characters:
Vlastnosť Characters nemá zmysel používať na tlačidle, takže dal by som to preč aj pri tých ostatných, hoci tam to funguje aj tak, ako to máš teraz.
Neviem, čo máš na mysli pod modrým highlight keywords.
no ved toto:
je to z ineho pc, excel 2016 ale na mojom je to to iste. modrou su tie klucove vba slova. ked mam tmavu temu, normalne cierne veci sa zmenia na svetle co je ok, tak ako ma byt, ale tieto highlighted zostanu tmavo modro a tmavo zeleno. to potrebujem zmenit.
tuto cervenou farbou tlacitko ma zostat tak ako je. ja chcem zmenit tie sheety co su modrou a ked na 1 uz kliknes a vratis sa spat, je to fialove. to tiez je zle vididelne pri tmavej teme windowsu.
chapes ?
Farby textu vo VBA editore sa dajú nastaviť v Tools / Options... / Editor Format.
Farby hyperlinkov si nastavíš podobne, ako už teraz nastavuješ Font.Underline = xlUnderlineStyleNone. Stačí tam pridať nastavenie hodnoty pre Font.Color.
