Maxthon 2.0.5 Forum Build (2.0.5.7684)
upozornuju ze jde o Forum Build ,public version vyjde po prvnich zkusenostech
[New Feature]
+ New Split View Mode
+ button plugins can set default location in plugin.ini (DefaultLocation=MenuBar/ToolBar/StatusBar)
+ plugin icon support png, jpg, bmp format
+ improved tab dragging in the tab bar[changes]
* fixed some problems with multimonitor
* fixed problem that "up" key not work in address bar when auto complete
* fixed a conflict with ime application
* fixed problem that change to filter pack version number not work
* add confirmation when delete tab in collector
* sidebar tabs are set to show the icon only
* some skin icons updated
* the maximum number of mouse gesture action number set to 3
* site icon in tab show faster
* fixed problem that some items may not list in filtered list
* fixed an address bar display problem when tabs are opened by external program
* fixed problem that maxthon may not exit when computer is closed with "Close To System Tray"option enabled
* fixed problem that "Enable Quick Search in Address Bar" may not work
* fixed a browser safety issue
* fixed a problem that deleting sidebar plugin may crash
* fixed problem that ">>" button of favorites bar may not work
* fixed some menu and shortcut conflict problems
* fixed drawing problem of new tab button in the tab bar;
* Favorite manager can set/unset most favorites
* fixed problem that deleted skins continue to show in Setup Center
* fixed display problem of Most Favorites which have "&" in title
* fixed crash when left click Undo menu after right click
* fixed flickering when title is clicked under "customize..." mode
* fixed some crash problems
* fixed favicon url problem (use url specified in webpage)
* fixed problem that context menu search does not work if search bar is hidden
* fixed crash when switch to different application while capturing region
tak uz na tom jedu - funguje to prima![]:)](https://static.poradna.net/images/smiley/evilsmile.gif)
reader mod (New Split View Mode) vali jako drak
pripadny problemy:
jelikoz je Max plne uzpusobitelnej muze delat problem rozhozeni ikon +"zdvojeni" moznosti pridani ikon,reader zalozky a ouska zalozek muzou byt nestandardne umistena (nalepena vsechny na stranu).
jednoduchy reseni:
vyresetovat pozice a pocet tlacitek a zrestartit Maxe (klidne i dvakrat) - nezapomente ze resetuje kazda lišta(menu,ikony,stavova lista...)
pak to nabehne do cely krasy
reset takto:
![[http://img219.imageshack.us/img219/1338/resetsq1.th .png]](http://img219.imageshack.us/img219/1338/resetsq1.th.png)
fullscreen bez problemu
