Moc ne.
Od toho je WSH:
nezkouseno, na vlastni nebezpeci:)
Removing registry entries
To remove an entire "tree" from the registry using REGEDIT and a .REG file, just add a minus sign before the tree name:
REGEDIT4
[-HKEY_CURRENT_USER\DummyTree]
wi ll remove the entire tree "DummyTree".
To remove an individual item from the registry, place the minus sign after the equal sign:
REGEDIT4
[HKEY_CURRENT_USER\DummyTree]
"Val ueToBeRemoved"=-
Minus na zacatku jakehokoliv klice spolehlive funguje, jen jaksi nevratne v pripade omylu.
Problem vyresen, redakce upozornena.
Diky!
