Podporuje tento procesor EM64T alebo nie?
Potrebujem zistit ci dany procesor podporuje EM64T.
Dovod - Chystam sa na stare PC nainstalovat NAS4Free a ten vyzaduje procesor ktory podporuje EM64T.
V poziadavkach sa okrem ineho pise:
- Intel® Pentium® 4s and Celeron Ds using the “Cedar Mill” core have EM64T support.
- Some Intel® Pentium® 4s and Celeron Ds using the “Prescott” core have EM64T support. See the Intel Processor Spec Finder for the definitive answer about EM64T support in Intel processors.
Ale neviem ani za svet zistit ktory procesor presne mam.
Everest vypisuje o procesore toto:
CPU Properties:
CPU Type Intel Pentium 4A, 2400 MHz (18 x 133)
CPU Alias Northwood, A80532
CPU Stepping C1
Instruction Set x86, MMX, SSE, SSE2
Original Clock 2400 MHz
Min / Max CPU Multiplier 18x / 18x
Engineering Sample No
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed)
CPU Physical Info:
Package Type 478 Pin uPGA
Package Size 3.50 cm x 3.50 cm
Transistors 55 million
Process Technology 6M, 0.13 um, CMOS, Cu, Low-K
Die Size 131 mm2
Core Voltage 1.475 - 1.55 V
I/O Voltage 1.475 - 1.55 V
Typical Power 38.7 - 89.0 W (depending on clock speed)
Maximum Power 49 - 109 W (depending on clock speed)
cpu-z
jinak: http://ark.intel.com/products/27438/Intel-Pentium- 4-Processor-2_40-GHz-512K-Cache-533-MHz-FSB
Vdaka.
Nakoniec som to nasiel aj v tom reporte co ukazal EVEREST, neviem kde som pozeral predtym...:
64-bit x86 Extension (AMD64, EM64T): Not Supported
Tak to je blbe ze to nepodporuje, budem musiet vymysliet nieco ine.... (alebo najst trosku novsie PC )
