PAGE_FAULT_IN_NONPAGED_AREA (50) Invalid system memory was referenced. This cannot be protected by try-except, it must be protected by a Probe. Typically the address is just plain bad or it is pointing at freed memory. Arguments: Arg1: fffff900c266f084, memory referenced. Arg2: 0000000000000000, value 0 = read operation, 1 = write operation. Arg3: fffff9600024779c, If non-zero, the instruction address which referenced the bad memory address. Arg4: 0000000000000000, (reserved)
Debugging Details: ------------------
Could not read faulting driver name TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800032bd0e0 GetUlongFromAddress: unable to read from fffff800032bd198 fffff900c266f084
FAULTING_IP: win32k!GreSetRedirectionSurfaceSignaling+104 fffff960`0024779c f6465c01 test byte ptr [rsi+5Ch],1
MM_INTERNAL_CODE: 0
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: dwm.exe
CURRENT_IRQL: 0
TRAP_FRAME: fffff880065f5980 -- (.trap 0xfffff880065f5980) NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=fffffa8005e74060 rbx=0000000000000000 rcx=fffff880065f5ae0 rdx=fffff900c021a898 rsi=0000000000000000 rdi=0000000000000000 rip=fffff9600024779c rsp=fffff880065f5b10 rbp=ffffffffa91211b1 r8=0000000000000001 r9=00000000000011b1 r10=000000000386f7a0 r11=fffff880065f5b08 r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei ng nz na po nc win32k!GreSetRedirectionSurfaceSignaling+0x104: fffff960`0024779c f6465c01 test byte ptr [rsi+5Ch],1 ds:00000000`0000005c=?? Resetting default scope
LAST_CONTROL_TRANSFER: from fffff800031061e4 to fffff80003086f00
Crash Dump Analysis provided by OSR Open Systems Resources, Inc. (www.osr.com) Online Crash Dump Analysis Service See www.osronline.com for more information Windows 7 Kernel Version 7600 MP (2 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7600.16385.amd64fre.win7_rtm.090713-1255 Machine Name: Kernel base = 0xfffff800`03015000 PsLoadedModuleList = 0xfffff800`03252e50 Debug session time: Sat Jan 17 18:13:45.209 2015 (UTC - 5:00) System Uptime: 0 days 0:31:56.879
takže standardka- testuj ram.
Zkoušel jsem utilitku ve winu "Diagnostika paměti Windows" a neukázalo to žádné problémy. Mám spíše zkusit MemTest?
To vůbec nemusí vypovídat o chybě paměti.
nemusí. může.
nepoznám z toho, jestli máš servicepack 1. z reportu taky hádám chybu paměti - zkus ještě jiný analyzátor (nirsoft bsod viewer) a nějaký jiný memtest.
Říkáš poslední dobou… jak dlouho se ti to děje? Nedělal jsi předtím nějaké změny v HW nebo SW konfiguraci počítače, kupříkladu nová grafická karta, nebo update jejích ovladačů?
Od té doby, co jsem začal hrát wowko :D od pátku. Nejdříve to dělali soubory cdd.dll a ntoskrnl.exe pak ntoskrnl.exe a win32k.sys a teď jen ntoskrnl.exe.. Musím si sehnat flashku a dát si tam ten memtest, protože když to dělám z CD, tak se mi tam neuloží log z testu
Crash Dump Analysis provided by OSR Open Systems Resources, Inc. (www.osr.com) Online Crash Dump Analysis Service See www.osronline.com for more information Windows 7 Kernel Version 7600 MP (2 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7600.16792.amd64fre.win7_gdr.110408-1633 Machine Name: Kernel base = 0xfffff800`0300f000 PsLoadedModuleList = 0xfffff800`0324ce50 Debug session time: Sun Jan 18 09:08:35.994 2015 (UTC - 5:00) System Uptime: 0 days 1:28:10.579 ************************************************** ***************************** * * * Bugcheck Analysis * * * ************************************************** *****************************
SYSTEM_SERVICE_EXCEPTION (3b) An exception happened while executing a system service routine. Arguments: Arg1: 00000000c0000005, Exception code that caused the bugcheck Arg2: fffff96000166923, Address of the instruction which caused the bugcheck Arg3: fffff880065c7030, Address of the context record for the exception that caused the bugcheck Arg4: 0000000000000000, zero.
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
Automatický update nepoužívám, vždy to jen vyskočí, že je nový driver, tak ho stáhnu, ale jinak nic. Nainstaloval jsem ovladač pro grafiku, chipset, zvukovku
správné pořadí instalace ovladačů: chipset, pak grafika a zbytek.
jiný memtest a jiný bsod debugger by mohly pomoct, ale když nejdou spustit ...
Aspoň ten dump mohl hodit, když už nic jiného…
vždyť jsem sem ten výpis hodil
Myslel jsem ten *.dmp soubor…
minidump-rar Tady máš všechny dumpy i ten, který se mi stal před minutou a to jsem smazal ovladače a nainstaloval sjem znovu - Chipset, Grafika, Realtek
Arguments:
address.
Debugging Details:
fffff900c266f084
FAULTING_IP:
MM_INTERNAL_CODE: 0
BUGCHECK_STR: 0x50
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`065f5818 fffff800`031061e4 : 00000000`00000050 fffff900`c266f084 00000000`00000000 fffff880`065f5980 : nt!KeBugCheckEx
fffff880`065f5820 fffff800`03084fee : 00000000`00000000 fffff900`c06e3a60 fffffa80`05e74100 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x42907
fffff880`065f5980 fffff960`0024779c : 00000000`00000000 ffffffff`a91211b1 00000000`0386f840 fffff8a0`01c69000 : nt!KiPageFault+0x16e
fffff880`065f5b10 fffff960`0026a969 : 00000000`00000001 fffff880`065f5c60 00000000`0386f840 00000000`000089f2 : win32k!GreSetRedirectionSurfaceSignaling+0x104
fffff880`065f5b60 fffff800`03086153 : fffffa80`05e74060 fffffa80`05e866e0 fffffa80`05eb91d0 fffffa80`05e866e0 : win32k!NtGdiHLSurfSetInformation+0x209
fffff880`065f5be0 000007fe`ff324efa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0386f778 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7fe`ff324efa
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: win32k!GreSetRedirectionSurfaceSignaling+104
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: win32k
IMAGE_NAME: win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc5e0
FAILURE_BUCKET_ID: X64_0x50_win32k!GreSetRedirectionSurfaceSignaling+ 104
Machine Name:
nemusí. může.
Machine Name:
Arguments:
Debugging Details:
FAULTING_IP:
win32k!HmgLockEx+a3
fffff960`00166923 0fb7430c movzx eax,word ptr [rbx+0Ch]
CONTEXT: fffff880065c7030 -- (.cxr 0xfffff880065c7030)
rax=fffff900c0210000 rbx=0000000000000000 rcx=fffffa8005740380
rdx=fffff900c0210000 rsi=0000000000010000 rdi=fffff900c0210000
rip=fffff96000166923 rsp=fffff880065c7a00 rbp=0000000000000000
r8=0000000000000001 r9=0000000000000000 r10=0000000000000000
r11=fffff880065c7a68 r12=00000000036cc200 r13=0000000000000000
r14=0000000000000001 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010246
win32k!HmgLockEx+0xa3:
fffff960`00166923 0fb7430c movzx eax,word ptr [rbx+0Ch] ds:002b:00000000`0000000c=????
BUGCHECK_STR: 0x3B
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff9600032c1e0 to fffff96000166923
STACK_TEXT:
fffff880`065c7a00 fffff960`0032c1e0 : fffff900`c2300420 00000000`00000001 ffffffff`c5120c68 fffff900`c2168cd0 : win32k!HmgLockEx+0xa3
fffff880`065c7a70 fffff960`0032b6de : fffff900`c2300420 00000000`00000000 00000c68`624d4653 00000000`0000001d : win32k!SFMLOGICALSURFACE::OwnsSurfaceCleanup+0x40
fffff880`065c7aa0 fffff960`0032c5e3 : 00000000`00000000 ffffffff`c5120c68 fffff900`c2300420 00000000`036cc2e0 : win32k!SFMLOGICALSURFACE::DeInitialize+0x4e
fffff880`065c7ae0 fffff960`00287c9f : 00000000`00000000 fffff900`c00c0010 fffff900`c2300420 00000000`00000020 : win32k!bhLSurfDestroyLogicalSurfaceObject+0x4b
fffff880`065c7b20 fffff960`002a9278 : 00000800`00000001 00000000`00000001 fffff880`065c7c60 00000000`00000000 : win32k!GreSfmCloseCompositorRef+0x10f
fffff880`065c7b60 fffff800`0307e953 : fffffa80`05740380 00000000`020cf7a0 000007fe`f950d610 00000000`00000000 : win32k!NtGdiHLSurfSetInformation+0x1a8
fffff880`065c7be0 000007fe`fdab4efa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`020cf1f8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7fe`fdab4efa
FOLLOWUP_IP:
win32k!HmgLockEx+a3
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: win32k!HmgLockEx+a3
MODULE_NAME: win32k
DEBUG_FLR_IMAGE_TIMESTAMP: 54163648
STACK_COMMAND: .cxr 0xfffff880065c7030 ; kb
FAILURE_BUCKET_ID: X64_0x3B_win32k!HmgLockEx+a3
Followup: MachineOwner
DAlší!
Co jsi dělal, než se to zhroutilo?
Zkus si aktualizovat ovladače, speciálně na grafickou kartu.
A nebo sem přilož ten dump.
Vždy se stane to samé. Hraju WoW, přijde mi zpráva na FB, tak ATL+Tab hru shodím a najednou se to sekne, nejdřív milion proužků barvy a pak BSOD.
Takže aktualizuj ovladače (grafika, chipset) a pak dej vědět.
Grafiku mam aktualizovanou, mám stáhnuto AMD Catalyst driver (14.12 Catalyst Omega software) a Chipset mám ze stránek Gigabyte.
pokud je to AMD čipset, tak potřebuješ čipset driver odpovídající Omega driveru (tedy 14.12), jinak to blbne přesně takto.
http://www2.ati.com/drivers/amd-catalyst-omega-14. 12-sb-sata-ahci-win8.1-win7.exe
log z memtestu nepotřebuješ - leda k případné reklamaci. jinak stačí, když rozeznáš červenou a zelenou barvu.
jiný debugger jsi taky nezkusil, mohlo být víc informací.
cdd.dll: nepoužíváš taky automatický update ovladačů?
minidump-rar
MemTest vyšel dobrý, žádný Error ani příznak
