Čtení formuláře multipart/form-data v servletu.
Snažím se uploadovat soubory v servletu a současně odeslat z formuláře checkbox.
Formulář:
<form method="post" action="" enctype="multipart/form-data">
Metoda do POST:
@Override
protected void doPost(HttpServletRequest req, HttpServletResponse resp) throws ServletException, IOException {
HttpServletRequestWrapper a = new HttpServletRequestWrapper(req);
String[] parameterNotifiEmail = a.getParameterValues(PARAMETER_NOTIFI_EMAIL);
String[] parameterPriority = a.getParameterValues(PARAMETER_PRIORITY);
System.out.println("-------------------------------------------------------------");
System.out.println("2: " + Arrays.toString(parameterNotifiEmail));
System.out.println("3: " + Arrays.toString(parameterPriority));
// configures upload settings
DiskFileItemFactory factory = new DiskFileItemFactory();
// sets memory threshold - beyond which files are stored in disk
factory.setSizeThreshold(MEMORY_THRESHOLD);
// sets temporary location to store files
factory.setRepository(new File(System.getProperty("java.io.tmpdir")));
ServletFileUpload upload = new ServletFileUpload(factory);
// sets maximum size of upload file
upload.setFileSizeMax(MAX_FILE_SIZE);
// sets maximum size of request (include file + form data)
upload.setSizeMax(MAX_REQUEST_SIZE);
// constructs the directory path to store upload file
// this path is relative to application's directory
String uploadPath = getServletContext().getRealPath("")
+ File.separator + UPLOAD_DIRECTORY;
// creates the directory if it does not exist
File uploadDir = new File(uploadPath);
if (!uploadDir.exists()) {
uploadDir.mkdir();
try {
// parses the request's content to extract file data
@SuppressWarnings("unchecked")
List<FileItem> formItems = upload.parseRequest(req);
if (formItems != null && formItems.size() > 0) {
// iterates over form's fields
for (FileItem item : formItems) {
// processes only fields that are not form fields
if (!item.isFormField()) {
String fileName = new File(item.getName()).getName();
String filePath = uploadPath + File.separator + fileName;
File storeFile = new File(filePath);
// saves the file on disk
item.write(storeFile);
req.setAttribute("message",
"Upload has been done successfully!");
System.out.println(fileName); //<------------ FILE
} else {
System.out.println("NENI NIC V LISTU");
} catch (Exception ex) {
"There was an error: " + ex.getMessage());
Problém je v tom, mi nejde číst soubory a současně číst parametr check box, když zakomentím jedno, funguje druhé, když zakomentím druhé funguje první.
Jinak je v tom druhém NULL.
Nechápu proč, co dělám špatně?
Třída má anotaci
@WebServlet("/admin/add-request")
@MultipartConfig(fileSizeThreshold = 1024 * 1024 * 10, // 10 MB
maxFileSize = 1024 * 1024 * 50, // 50 MB
maxRequestSize = 1024 * 1024 * 100) // 100 MB
Ach jo, zas ty Servlety...
Normalne se to dela takhle: uploading-files
Vše jsem měl z examplů a tutoriálků, ale nechápu proč mi vždy fungovalo buď jedno, nebo druhé.
na začiatok skontroluj http request a response, či tam tie dáta naozaj máš
zlaté php, stručne jasne na pár riadkov
Vyřešil jsem to tím, že jsem udělal 2 stránky a dva formuláře, jinak bych se z toho asi PO*. Protože to nejde. Nevím. Už to řešit nebudu.
