TFT LCD 3.5 inch Display Touch Screen Module Arduino UNO R3
Zdravím.
Koupil jsem si s ali displej pro arduino uno a nemužu ho rozchodit.
Našel jse něco tady.
index.php
Na netu pišou že se ma nahrat do arduina LCD_ID_readreg.ino a přes serial monitor to vypiše info o displeji.
Neporadí někdo?
Read Registers on MCUFRIEND UNO shield
controllers either read as single 16-bit
e.g. the ID is at readReg(0)
or as a sequence of 8-bit values
in special locations (first is dummy)
reg(0x0000) 00 00 ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 00 00 00 00 Manufacturer ID
reg(0x0009) 00 00 00 00 00 Status Register
reg(0x000A) 08 08 Get Powsr Mode
reg(0x000C) 66 66 Get Pixel Format
reg(0x0061) 00 00 RDID1 HX8347-G
reg(0x0062) 00 00 RDID2 HX8347-G
reg(0x0063) 00 00 RDID3 HX8347-G
reg(0x0064) 00 00 RDID1 HX8347-A
reg(0x0065) 00 00 RDID2 HX8347-A
reg(0x0066) 00 00 RDID3 HX8347-A
reg(0x0067) 00 00 RDID Himax HX8347-A
reg(0x0070) 00 00 Panel Himax HX8347-A
reg(0x00A1) 00 00 00 00 00 RD_DDB SSD1963
reg(0x00B0) 00 00 RGB Interface Signal Control
reg(0x00B4) 00 00 Inversion Control
reg(0x00B6) 00 00 00 00 00 Display Control
reg(0x00B7) 00 00 Entry Mode Set
reg(0x00BF) 01 01 22 15 81 00 ILI9481, HX8357-B
reg(0x00C0) 00 00 3B 00 02 00 01 00 43 Panel Control
reg(0x00C8) 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA
reg(0x00CC) 00 00 Panel Control
reg(0x00D0) 00 00 00 Power Control
reg(0x00D2) 03 03 24 04 00 NVM Read
reg(0x00D3) 03 03 24 04 ILI9341, ILI9488
reg(0x00DA) 00 00 RDID1
reg(0x00DB) 00 00 RDID2
reg(0x00DC) 00 00 RDID3
reg(0x00E0) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA-P
reg(0x00E1) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA-N
reg(0x00EF) 00 00 00 00 00 00 ILI9327
reg(0x00F2) 07 07 00 00 00 00 00 00 00 00 00 00 Adjust Control 2
reg(0x00F6) 00 00 00 00 Interface Control
Kazdy display ma nejaky datasheet, a nasledne podla toho kam je to zapojene mozes s nim komunikovat. Idealne je vediet co robis a ne lepit veci ktorym nerozumies.
P.S. to co si sem vlozil neni ziaden spustitelny kod.
To je to info
On sa ta, ale pytal. ci to mas vobec spravne zapojene.
Ty uz chces komunikovat a este si neskontroloval ani zapojenie.
Tak toto jsem moc nepochopil.
Displej ma natvrdo piny, ktere se zastrčí do arduina.
Popřehazovat to nejde.
Je to tento.
http://www.ebay.com/itm/361538912387?_trksid=p2057 872.m2748.l2649&ssPageName=STRK%3AMEBIDX%3AIT
A to co tam pisu si uz skusal?
Datasheet pre ILI9327 si uz skusal hladat?
http://forum.arduino.cc/index.php?topic=37960.5;wa p2
P.S. datasheet pre ILI9327 je hned prvy odkaz google, ked do neho zadas slovo ILI9327. Uz si si ho precital a pochopil? Veci sa neprogramuju nahodne podla nejakych polepencov z for, to potom neni programovanie ale lepenie nefunkcnej sracky.
Hm.Tak to je už mimo mně
Kamoš mi pujčil takový.
http://www.banggood.com/3_5-Inch-TFT-Color-Screen- Module-320-X-480-Support-Arduino-UNO-Mega2560-p-10 22298.html
Zasunul jsem ho do arduina, stahnul tu knihovnu co je na te strance banggood.com a vše fungovalo na první pokus.
Myslel jsem, že když to bylo tak jednoduche, že dam i toto.
Tak nic, i tak dik moc.
