Skládání modpacku do MC
Zdravím, nevím zda se někdo tady najde ale vyzná se někdo kde je problém?
[spoiler]CodeChickenLib Invalid Fingerprint Reports:
CodeChickenCore Invalid Fingerprint Reports:
EnderIO: Found the following problem(s) with your installation (That does NOT mean that Ender IO caused the crash or was involved in it in any way. We add this information to help finding common problems, not as an invitation to post any crash you encounter to Ender IO's issue tracker. Always check the stack trace above to see which mod is most likely failing.):
* Optifine is installed. This is NOT supported.
* The RF API that is being used (1.5.0 from (guessing) null) differes from that that is reported as being loaded (1.8.9R1.2.0B1 from valkyrielib-1.10.2-0.10.6.jar).
It is a supported version, but that difference may lead to problems.
This may (look up the meaning of 'may' in the dictionary if you're not sure what it means) have caused the error. Try reproducing the crash WITHOUT this/these mod(s) before reporting it.
Detailed RF API diagnostics:
* RF API class 'EnergyStorage' is loaded from: jar:file:/C:/Users/Dominik/Desktop/MultiMC/instances/Magicatech/.minecraft/mods/BrandonsCore-1.10.2-2.1.14.137-universal.jar!/cofh/api/energy/EnergyStorage.class
* RF API class 'IEnergyConnection' is loaded from: jar:file:/C:/Users/Dominik/Desktop/MultiMC/instances/Magicatech/.minecraft/mods/BrandonsCore-1.10.2-2.1.14.137-universal.jar!/cofh/api/energy/IEnergyConnection.class
* RF API class 'IEnergyContainerItem' is loaded from: jar:file:/C:/Users/Dominik/Desktop/MultiMC/instances/Magicatech/.minecraft/mods/BrandonsCore-1.10.2-2.1.14.137-universal.jar!/cofh/api/energy/IEnergyContainerItem.class
* RF API class 'IEnergyHandler' is loaded from: jar:file:/C:/Users/Dominik/Desktop/MultiMC/instances/Magicatech/.minecraft/mods/BrandonsCore-1.10.2-2.1.14.137-universal.jar!/cofh/api/energy/IEnergyHandler.class
* RF API class 'IEnergyProvider' is loaded from: jar:file:/C:/Users/Dominik/Desktop/MultiMC/instances/Magicatech/.minecraft/mods/BrandonsCore-1.10.2-2.1.14.137-universal.jar!/cofh/api/energy/IEnergyProvider.class
* RF API class 'IEnergyReceiver' is loaded from: jar:file:/C:/Users/Dominik/Desktop/MultiMC/instances/Magicatech/.minecraft/mods/BrandonsCore-1.10.2-2.1.14.137-universal.jar!/cofh/api/energy/IEnergyReceiver.class
* RF API class 'IEnergyStorage' is loaded from: jar:file:/C:/Users/Dominik/Desktop/MultiMC/instances/Magicatech/.minecraft/mods/BrandonsCore-1.10.2-2.1.14.137-universal.jar!/cofh/api/energy/IEnergyStorage.class
* RF API class 'ItemEnergyContainer' is loaded from: jar:file:/C:/Users/Dominik/Desktop/MultiMC/instances/Magicatech/.minecraft/mods/BrandonsCore-1.10.2-2.1.14.137-universal.jar!/cofh/api/energy/ItemEnergyContainer.class
* RF API class 'TileEnergyHandler' is loaded from: jar:file:/C:/Users/Dominik/Desktop/MultiMC/instances/Magicatech/.minecraft/mods/BrandonsCore-1.10.2-2.1.14.137-universal.jar!/cofh/api/energy/TileEnergyHandler.class
[/spoiler]
[spoiler]Detailed Tesla API diagnostics:
* Tesla API class 'Tesla' could not be loaded (reason: java.lang.ClassNotFoundException: net.darkhax.tesla.Tesla)
* Tesla API class 'TeslaCapabilities' could not be loaded (reason: java.lang.ClassNotFoundException: net.darkhax.tesla.capability.TeslaCapabilities)
* Tesla API class 'ITeslaConsumer' could not be loaded (reason: java.lang.ClassNotFoundException: net.darkhax.tesla.api.ITeslaConsumer)
* Tesla API class 'ITeslaHolder' could not be loaded (reason: java.lang.ClassNotFoundException: net.darkhax.tesla.api.ITeslaHolder)
* Tesla API class 'ITeslaProducer' could not be loaded (reason: java.lang.ClassNotFoundException: net.darkhax.tesla.api.ITeslaProducer)
* Tesla API class 'BaseTeslaContainer' could not be loaded (reason: java.lang.ClassNotFoundException: net.darkhax.tesla.api.implementation.BaseTeslaContainer)
* Tesla API class 'BaseTeslaContainerProvider' could not be loaded (reason: java.lang.ClassNotFoundException: net.darkhax.tesla.api.implementation.BaseTeslaContainerProvider)
* Tesla API class 'InfiniteTeslaConsumer' could not be loaded (reason: java.lang.ClassNotFoundException: net.darkhax.tesla.api.implementation.InfiniteTeslaConsumer)
* Tesla API class 'InfiniteTeslaConsumerProvider' could not be loaded (reason: java.lang.ClassNotFoundException: net.darkhax.tesla.api.implementation.InfiniteTeslaConsumerProvider)
* Tesla API class 'InfiniteTeslaProducer' could not be loaded (reason: java.lang.ClassNotFoundException: net.darkhax.tesla.api.implementation.InfiniteTeslaProducer)
* Tesla API class 'InfiniteTeslaProducerProvider' could not be loaded (reason: java.lang.ClassNotFoundException: net.darkhax.tesla.api.implementation.InfiniteTeslaProducerProvider)
!!!You are looking at the diagnostics information, not at the crash. Scroll up!!!
RebornCore:
Plugin Engine: 0
RebornCore Version: 2.13.6.142
Mixin Status: 1
Runtime Debofucsation 1
RenderEngine: 1
OptiFine Version: OptiFine_1.10.2_HD_U_E7
Render Distance Chunks: 8
Mipmaps: 4
Anisotropic Filtering: 1
Antialiasing: 0
Multitexture: false
Shaders: null
OpenGlVersion: 3.3.11672 Compatibility Profile Context
OpenGlRenderer: ATI Mobility Radeon HD 4650
OpenGlVendor: ATI Technologies Inc.
CpuCount: 2[/spoiler]
Tady je celý crash log
NGV7NLYj
Za pád může mód AbyssalCraft
Může být problém taky v tom, že se nesnese s módem Biomes O' Plenty (oba módy přidávají do hry nové biomy), nebo jen jeho verzí.
PS: Koukám, že se ti taky nenačítá Tesla API. To by ale pád hry nemělo způsobovat.
Jinak kategorie Hry bude asi vhodnější.
Dobře, díky moc.
