Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailemVyřešeno Nelze nastartovat PC
Zdravim poradnu...
Muj problem je,ze mi nejde nastartovat PC..Po uvodnim "logu" MS Win nabehne na par sekund modra smrt a PC se
restartuje,ale to dela dookola..Pritom ale,nuzovy rezim funguje bez problemu..Myslel jsem,jestli to nespusobili ovladace k TV karte,ktere jsem nainstaloval,ale i po odinstalovani je to stejny..
OS je Win Vista Ultimate 32bit.
Muze mi nekdo poradit?
Na té modré obrazovce smrti je asi něco napsáno, že? Poradit můžu - obnov systém ze zálohy.
host 07.03.2009 22:14
ta modra obrazovka je tak rychla,ze jsem rad,z eji zaregistruji,proto nemuzu napsat,co se na ni pise…
BAGR3210 07.03.2009 22:36
BAGR3210
Zkus jeste obnoveni systemu...
Dale Cooper 07.03.2009 23:16
Dale Cooper
V nouzovem rezimu vypni restart pri zavazne chybe (netusim ale kde je to ve Viste zahrabane...) a pa…
Dale Cooper 07.03.2009 22:17
Dale Cooper
Je tam napsano: A problem has been detected and Windows has been shut down to prevent damage to you…
BAGR3210 07.03.2009 23:13
BAGR3210
http://forum.zive.cz/viewtopic.php?f=956&t=1045427…
host 07.03.2009 23:16
Děkuji,pomohlo! poslední
BAGR3210 08.03.2009 12:33
BAGR3210
Je tam napsano:
A problem has been detected and Windows has been shut down to prevent damage to your computer.
If this is the first time you´ve seen this Stop error screen,restart your computer.If this screen appears again,follow these step:
Check to be sure you have adequate disk space.If a driver is identified in the stop message,disable the driver or check with the manufacturer for driver updat.Try changing video adapters.
Check with your hadware vendor for any BIOS updates.Disable BIOS memory options such as caching or shadowing.If you need to usw Save Mode to remore or disable components,restart your computer,press F8 to select Advanced Startup Options,and then select Safe Mode.
Technical information:
STOP: 0x0000007E (0x0000005,0x8A8BE4E9,0x83694880,0x8369457C)
Jelikoz moje anglictina je hodne slaba,tak jsem to radsi napsal vsechno...
