Přidat otázku mezi oblíbenéZasílat nové odpovědi e-mailem ESP8266 webserver formulář
Zdravím
Hledám způsob jak udělat jednoduchý formulář něco jako pro vložení SSID a hesla tady jsem něco našel ale nejsem si jistý :-(
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp32-esp8266-input-data-html-form/
  Permission is hereby granted, free of charge, to any person obtaining a copy
  of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
#include <Arduino.h>
#ifdef ESP32
  #include <WiFi.h>
  #include <AsyncTCP.h>
#else
  #include <ESP8266WiFi.h>
  #include <ESPAsyncTCP.h>
#endif
#include <ESPAsyncWebServer.h>
AsyncWebServer server(80);
// REPLACE WITH YOUR NETWORK CREDENTIALS
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
const char* PARAM_INPUT_1 = "input1";
const char* PARAM_INPUT_2 = "input2";
const char* PARAM_INPUT_3 = "input3";
// HTML web page to handle 3 input fields (input1, input2, input3)
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html><head>
  <title>ESP Input Form</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  </head><body>
  <form action="/get">
    input1: <input type="text" name="input1">
    <input type="submit" value="Submit">
  </form><br>
    input2: <input type="text" name="input2">
  </form><br>
    input3: <input type="text" name="input3">
  </form>
</body></html>)rawliteral";
void notFound(AsyncWebServerRequest *request) {
  request->send(404, "text/plain", "Not found");
void setup() {
  Serial.begin(115200);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  if (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("WiFi Failed!");
    return;
  Serial.println();
  Serial.print("IP Address: ");
  Serial.println(WiFi.localIP());
  // Send web page with input fields to client
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html);
  // Send a GET request to <ESP_IP>/get?input1=<inputMessage>
  server.on("/get", HTTP_GET, [] (AsyncWebServerRequest *request) {
    String inputMessage;
    String inputParam;
    // GET input1 value on <ESP_IP>/get?input1=<inputMessage>
    if (request->hasParam(PARAM_INPUT_1)) {
      inputMessage = request->getParam(PARAM_INPUT_1)->value();
      inputParam = PARAM_INPUT_1;
    // GET input2 value on <ESP_IP>/get?input2=<inputMessage>
    else if (request->hasParam(PARAM_INPUT_2)) {
      inputMessage = request->getParam(PARAM_INPUT_2)->value();
      inputParam = PARAM_INPUT_2;
    // GET input3 value on <ESP_IP>/get?input3=<inputMessage>
    else if (request->hasParam(PARAM_INPUT_3)) {
      inputMessage = request->getParam(PARAM_INPUT_3)->value();
      inputParam = PARAM_INPUT_3;
    else {
      inputMessage = "No message sent";
      inputParam = "none";
    Serial.println(inputMessage);
    request->send(200, "text/html", "HTTP GET request sent to your ESP on input field ("
                                     + inputParam + ") with value: " + inputMessage +
                                     "<br><a href=\"/\">Return to Home Page</a>");
  server.onNotFound(notFound);
  server.begin();
void loop() {
A čím že si to nejsi jistý?
Wikan 21.12.2019 13:42
Ale já jsem si udělal na ESP8266 ESP-01 měření teploty čidlem DS18b20 který mě posílá teplotu po int…
Víťa 21.12.2019 14:12
Víťa
No a čím si teda nejsi jistý?
Wikan 21.12.2019 14:18
Při překladu mě to vyhazuje chyby nemohu se pohnout dál 3-[ někdo kdo by mě pomohl fungujícím příkla…
Víťa 21.12.2019 18:13
Víťa
Jaké chyby? To z tebe opravdu musíme stále tahat informace?
host 21.12.2019 18:15
Tak jedine, co jsem pochopil, tak maš ESP8266 ESP-01 a na něm teploty čidlem DS18b2. Zbytek jsem nep…
BigSandy 21.12.2019 19:52
BigSandy
Ano teď to mám nastaveno na domácí síť a já potřebuji mít možnost aby jsem to mohl bez úpravy firmwa…
Víťa 21.12.2019 20:07
Víťa
Něco takoveho? https://randomnerdtutorials.com/wifimanager-with-esp8266-autoconnect-custom-parameter…
BigSandy 21.12.2019 20:20
BigSandy
To je věc:)) něco takového ještě nebudu skákat do stropu zítra to zkusím teď to píši na telefonu zat…
Víťa 21.12.2019 20:48
Víťa
Je tam přiklad kdy se zavola WiFiManager po stisknutí tlačítka. Nebo v zakladním sample pro ESP8266…
BigSandy 21.12.2019 22:31
BigSandy
Tak já bych potřeboval spojit tyto dva projekty ten první projekt nastaví přístupové údaje do WiFi s…
Víťa 22.12.2019 20:39
Víťa
Takže potisící. Proč proboha screenshoty a ne zdrojový kód v textové podobě?
Wikan 22.12.2019 20:41
tak to máš textové podobě #include <ESP8266WiFi.h> #include <DNSServer.h> #include <ESP8266WebServ…
Víťa 22.12.2019 20:50
Víťa
Proč mám opět silný pocit, že řešíš jiný problém, než na jaký se ptáš?
Wikan 21.12.2019 22:36
Si přečti, co jsem Ti tu napsal, když jsem tu dal ten odkaz. Takto Ti bude wifiManager najíždět při…
BigSandy 23.12.2019 10:34
BigSandy
Já bych potřeboval zdroják který je ve WiFi relé a to mě nikdo neposkytne asi .Ten včerejší nástřel…
Víťa 23.12.2019 11:32
Víťa
Máš pravdu nečetl jsem to pozorně ty myslíš dát to do podmínky :i: .A jak ta podmínka by měla vypada…
Víťa 23.12.2019 16:12
Víťa
Já jsem to upravil takto označeno ************* je to dobře? zatím nevím jak předávat SSID a PASSWO… poslední
Víťa 26.12.2019 19:55
Víťa
Ale já jsem si udělal na ESP8266 ESP-01 měření teploty čidlem DS18b20 který mě posílá teplotu po internetu ven , prozatím to mám připojeno pevně do mé domácí sítě ale já bych potřeboval aby se ti připojovalo i na druhé sítě něco jako WiFi relé chci to udělat tak abych mohl ty přihlašovací údaje vložit do formuláře . Tak proto si skoušim nebo hledám vhodný příklad. díky
Ano teď to mám nastaveno na domácí síť a já potřebuji mít možnost aby jsem to mohl bez úpravy firmware a znovu nahrátí do do ESP8266 připojit na druhou WiFinu a proto potřebuji tam narvat webovský formulář
Nebo v zakladním sample pro ESP8266 je ve void setup toto
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Uprav a dej mu třeba 50 pokusu a pokud se nepřipoji, zavolej WiFiManager.
Už jsem to několikrat použival a spokojený.
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
void setup() {
  // put your setup code here, to run once:
  WiFiManager wifiManager;
  wifiManager.startConfigPortal("ArduinoAP");
  //if you get here you have connected to the WiFi
  Serial.println("connected...");
void loop() {
  // put your main code here, to run repeatedly:
 //http://www.urel.feec.vutbr.cz/MPOA/2015/esp8266-ds18b20
  #include <OneWire.h>
  #include <DallasTemperature.h>
  #define ONE_WIRE_BUS 2
  OneWire oneWire(ONE_WIRE_BUS);                 // Inicializace DS18B20 na pinu GPIO2
  DallasTemperature DS18B20(&oneWire);
  const char* ssid     = "";               // Nastavení připojení k síti
  const char* password = "";
  const char* host = "api.thingspeak.com";       // Informace pro připojení k thingspeak.com
  const char* APIkey   = "";
  bool scnd = false;
void setup() {
    Serial.begin(115200);                        // Otevření komunikace po sériové lince
    delay(10);
    Serial.println();
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);                  // Inicializace připojení k síti
    while (WiFi.status() != WL_CONNECTED) {      // Potvrzení připojení k síti
      delay(500);
      Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
    Serial.println();
void loop() {
   delay(30000);                                // Měření a odesílání teploty probíhá v intervalu cca 30s
    float temp;
    DS18B20.requestTemperatures();               // Získání informace o teplotě teploty
    temp = DS18B20.getTempCByIndex(0);
    Serial.print("Temperature: ");
    Serial.println(temp);
    char charVal[12];
    dtostrf(temp, 8, 2, charVal);                // Konverze vyčtené teploty do stringu
                                                 // (hodnota, počet míst, počet desetinných míst,
                                                 // umístění stringu)
  if(scnd){
    Serial.print("connecting to ");
    Serial.println(host);
    WiFiClient client;
    const int httpPort = 80;
    if (!client.connect(host, httpPort)) {
      Serial.println("connection failed");
      return;
    String url = "/update?key=";                // Vytvoření URL pro odeslání informace o teplotě
    url += APIkey;
    url += "&field1=";
    url += charVal;
    Serial.print("Requesting URL: ");
    Serial.println(url);
                                                 // Odeslání požadavku na server
    client.print(String("GET ") + url + " HTTP/1.1\r\n" +
                 "Host: " + host + "\r\n" +
                 "Connection: close\r\n\r\n");
    delay(10);
    Serial.println();
    while (client.available()) {
      String line = client.readStringUntil('\r');
      Serial.print(line);                        // tisk informací přijatých ze serveru
    Serial.println();
    Serial.println("connection completed");      // potvrzení ukončení odesílání
    Serial.println();
    Serial.println();
   else
    Serial.println("uncorrect first temperatue");
    Serial.println();                            // Ošetření nesprávnosti první změřené hodnoty po připojení
    scnd=true;                                   // k napájení
díky za pomoc
Takto Ti bude wifiManager najíždět při každém spouštění.
Ani sis nepřečetl, co tam píše, a plácl jsi tu první přiklad co tam je.
To delay(30000) je také pěkná prasarna a mělo by se to řešit přes millis nebo Timer.h.
Máš pravdu nečetl jsem to pozorně ty myslíš dát to do podmínky :i: .A jak ta podmínka by měla vypadat přesnou syntaxi bych prosil já totiž jsem vyrostl na pascalu a delphi toto je jazyk C nebo něco podobného .Za druhé kde ten WiFiManager ukládá proměnné SSID a PASSWORD do paměti abych je mohl pak použít ? díky
Já jsem to upravil takto označeno ************* je to dobře? zatím nevím jak předávat SSID a PASSWORD ale to zatím neřeším
GPIO0 je na ESP-01 je při programování musí být na LOW ,jak zapojit tlačítko mám tam dát jako Pull UP odpor na zem nebo na 3V3 nebo to je zapnuto tímto pinMode(TRIGGER_PIN, INPUT_PULLUP)? díky
 *********** #define TRIGGER_PIN 0                          //GPIO0 na ESP8266 ESP-01 ***************
  const char* ssid     = "     ";               // Nastavení připojení k síti
  const char* password = "       ";
  bool scnd = false;
void setup() {
 *****    pinMode(TRIGGER_PIN, INPUT_PULLUP);********
*****    if(digitalRead(TRIGGER_PIN) == LOW) {***********
*****    WiFiManager wifiManager;                 ***********
*****   wifiManager.startConfigPortal("ArduinoAP");*********
    delay(10);
    Serial.println();
      delay(500);
      Serial.print(".");
    Serial.println("");
    Serial.println();
void loop() {
    float temp;
    char charVal[12];
  if(scnd){
    WiFiClient client;
      return;
    url += APIkey;
    url += "&field1=";
    url += charVal;
    delay(10);
    Serial.println();
    Serial.println();
    Serial.println();
    Serial.println();
   else
